Home Forums Software Discussions Adobe Software Creating opacity mask to outlines
  • Creating opacity mask to outlines
    Posted by Martyn on 22 May 2018 at 07:17
    Hi guys, wonder if anyone can help.
    When creating opacity masks- im creating a wood effect onto text, write the text out- over lay it onto the image-create opacity mask. Too this point everything is great. But now i want to create it to outlines and for the life of me i cant figure it out. Options expand appearance which i would expect to do it are not showing as available.
    Im using adobe cs4
    thanks
    Martyn replied 7 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jamie Wood
    22 May 2018 at 08:55
    I’d create the outlines first, then position over the top of the wood effect, and create a clipping mask.
  • Colin Crabb
    22 May 2018 at 09:30
    As Jamie said – convert text to outline (vector), overlay on top of wood effect – create clipping mask.
  • Martyn
    22 May 2018 at 10:38
    Thanks for the response, yes i already convert to outlines, then apply the opacity mask but i just get a box from where the image was. Lokks fine as preview- text with image within it but then go to outlines and just a box.
    hope this makes sense
  • Jamie Wood
    22 May 2018 at 11:03
    I’d skip the opacity mask, and just use the outlined text to create a clipping mask.
  • Colin Crabb
    22 May 2018 at 11:08
    The ‘wood effect’ image (I’m guessing its a Jpeg, Tiff etc – raster file) will be displayed as a ‘box’ if viewing in outlines mode, but will not be printed etc so shouldn’t be an issue.
  • Martyn
    22 May 2018 at 11:17
    i agree, with normal objects or single letters i create a clipping mask as you suggested but with a company name etc either it just goes blank or if i ungroup the letters then i get just one letter with the mask. Its strange and ive never got round it hence why i stated using opacity mask
  • Jamie Wood
    22 May 2018 at 11:21
    When you outline the text, try making a compound path from all of the letters. This should enable you to
    create the mask. Just make sure that the outlined text is on the top.
  • Shawn Bentley
    22 May 2018 at 17:51
    Select text then up at top of menu select image drop down menu then compound path at bottom and click make, then drop the image behind letters and select all text and image them cmd 7 (if using Mac ) or make clipping mask
  • Martyn
    23 May 2018 at 04:44
    You guys nailed it!!! i was missing the compound path part. Cant thank you enough. :praiseyou:
