Home Forums Sign Making Discussions Graphic Design Help Creating a Silhouette
  • Creating a Silhouette
    Posted by Paul Seamer on 5 June 2009 at 10:36
    I see a van yesterday with a silhouette of a push bike racer. It was cut black vinyl but was produced from a picture of him racing.
    How can I turn a photo into a silhouette to be cut?
    Paul
    Michael Dunn replied 16 years, 6 months ago 2 Members · 2 Replies
    5 June 2009 at 11:17
    This is just a guess.
    Take a photo of the item that is as good of a view as you can get with no obstructions.
    Import the pic into a photo program (even the cheap one I got from getting pix at Walmart)
    Change it to black and white.
    Adjust the contrast until it is as crisp as possible.
    Make the dpi fairly high when you save it.
    Import it into Corel.
    Change it to a black and white bitmap.
    Trace the bitmap.
    Ungroup and eliminate anything you don’t want in the picture.
    Select what you want to keep and combine the item.
    Node edit as need be, and you should have a passable vectored silhouette.
  • Michael Dunn
    17 June 2009 at 10:28
    if you have roland cut studio you can import a jpeg or bitmap
    go to image outline and turn up the density untill all the image becomes black and extract contour lines
    it should then run a vector line around the image
    or maybe use vector magic and delete all you dont need?
