Home Forums Software Discussions Adobe Software Coverting a PS file to Ai or Corel
  • Coverting a PS file to Ai or Corel
    Posted by Paul Seamer on 11 August 2010 at 12:24
    Hi Guys,
    I have been sent a few template files in PS but need to use it in Corel. Had other templates sent in Ai and all was ok. Any help appreciated as really need to get this done by the weekend.
    Paul
    Jan Storgaard replied 15 years, 4 months ago 5 Members · 16 Replies
  • 16 Replies
  • Jan Storgaard
    11 August 2010 at 16:13
    quote Paul Seamer:
    Hi Guys,
    Paul
    Errh! where is file to convert ?
    Jan
  • Russell Pavey
    11 August 2010 at 18:08
    i had this same problem just today and saved the file as an .eps file and then just imported in to Corel and to my amazement it opened. Not sure if it will work for you but worth a shot.
    Russ
  • Paul Seamer
    16 August 2010 at 09:21
    Hi Guys,
    Sorry for the late reply. I have just tried uploading a file for you to look at but it won’t let me. Where do I have to upload it to?
    Paul
    16 August 2010 at 10:23
    you should be able to upload it here, there are limitations on size and file types though
  • Paul Seamer
    16 August 2010 at 11:54
    it says the extension psd is not allowed?
    16 August 2010 at 12:08
    you can zip it
  • Paul Seamer
    16 August 2010 at 12:15
    has the magic worked?
    16 August 2010 at 12:47
    try this
    I think it should be ok,
  • Paul Seamer
    16 August 2010 at 13:32
    Still didn’t work. 😕 Not sure what to try next. I do have Photoshop on another computer (never use it) if there is a way I can edit in there just to leave cut lines and export to corel?
    Paul
    16 August 2010 at 13:53
    Paul thats basically what I did first
    opened in photshop and exported the paths to illustrator, but for some reason it did not work.
    I will have another go
  • Jan Storgaard
    16 August 2010 at 14:07
    quote Paul Seamer:
    Paul
    Not sure on WHAT u need – but i guess vectorfile shoul be the end result.
    BUT this psd file on only contain layers with graphic, NO paths!
    Jan
    16 August 2010 at 14:20
    sorry no luck.
  • Jan Storgaard
    16 August 2010 at 14:22
    Is this one good enough (vector) ?
    PDF – cant upload eps due to 400kb limit.
    If u need eps mail me: janfk AT storgaard.nu
  • Elena kalispera
    16 August 2010 at 19:40
    happens to me too. for me the file is there on the page when you open the document thats converted to paths in illustrator nothing is on the page but if you select all on the page and select an outline stroke you Will see your vector file appear. guess its a bug try it Peter..
  • Paul Seamer
    18 August 2010 at 16:20
    Hi Jan,
    Yes that worked perfect thanks. What was it that you did? I have a few other templates to do that have a bit more shape to them. Are you able to explain what you did?
    Paul
  • Jan Storgaard
    18 August 2010 at 16:44
    quote Paul Seamer:
    Hi Jan,
    Paul
    Hi Paul, i cheated. As i wrote earlier, no paths were present in the file, so i traced the image and corrected for distortion.
    If you want, i can do those you have left. If they are similar to the one i’ve done
    Jan
    you can reach me @: janfk@storgaard.nu
