Home Forums Sign Making Discussions Vinyl Covering side panel with gloss black vinyl
  • Covering side panel with gloss black vinyl
    Posted by Martyn on 17 December 2017 at 18:14
    Hi guys,
    ive attached a few pics which a customer is looking to replicate. Basically black vinyl within the panel to continue the window look. His design is just an angled straight line at the back no text.
    Im in two minds how to do this job. Ive seen a tutorial on here regarding creating a template of the panel but was also wondering how well wrapcut would do this job? ive used it a few times with good results but no sure how well it would work on the inside rounded edge of the panel.
    Any thoughts would be great. thanks
    Martyn replied 7 years, 10 months ago 11 Members · 17 Replies
  • 17 Replies
  • Luke Culpin
    17 December 2017 at 22:28
    I’d say that would be pretty easy to measure, redraw over a photo and cut to shape!
  • Denise Goodfellow
    18 December 2017 at 10:19
    Can’t you just do a quick measure, cut making sure you have a straight edge, then drop it in place and trim away everything else around the Windows edge with a knife
  • Chris Windebank
    18 December 2017 at 10:40
    Hopefully a straight edge top or bottom. Would use air release metamark M7 for ease then trim or wrap cut to finish
  • David Stevenson
    18 December 2017 at 13:58
    I find wrapcut great for straight lines, if you’ve corners to go round 3m’s design line is much better. It’s designed to handle corners šŸ™‚
  • Martyn
    18 December 2017 at 17:18
    ok the 3m design line sounds interesting, wrap cut has struggled with corners in the past i just end up cleaning it up free hand.
    Neither the top or bottom lines are straight, and i was planning on using avery 700 to do the job.
    Interesting points about drawing a template from a picture but i dont think this will be accurate enough. I have the outlines for this vehicle but never trust them with this sort of accuracy.
    Atm im going towards wrap cut, clean up any edges free hand (unless i can get 3m in time). Pre cut the angled line and lead with the straightest edge which looks to be the bottom.
    I will probably lay it wet without app tape, heat in along the wrap cut and go from there. If it doesnt work out then i know i chose the wrong option šŸ™‚
    thanks for the input guys. Once its done it will post a pic of the finished product
  • Kevin Flowers
    18 December 2017 at 19:46
    You could always go old school application tape and pencil, lay over vinyl and trim
  • Martyn
    19 December 2017 at 06:27
    Out of interest has anyone ever cut a panel shape from the impact outlines to see how far out it is?
  • Jamie Hunt
    19 December 2017 at 06:31
    Wrap cut is ok for straight lines you need the designer 3M Knife-less tape from Hexis it works brilliantly
    https://online.hexis.co.uk/Product-Deta … s%26Blades
  • Jamie Hunt
    19 December 2017 at 06:33
    quote Martyn Heath:
    Yes i have and its quite a bit out you tend to end up trimming it anyway go for the Designer knife-less tape from Hexis
    https://www.youtube.com/watch?v=1jywYn0O_J8
  • Peter Johnson
    19 December 2017 at 15:18
    Agree with everyone about the 3M DesignLine knifeless tape. Goes around corners and curves very well. I have done several ‘in-panel’ wraps/prints and the knifeless tape is brilliant.
  • Stuart Miller
    19 December 2017 at 15:30
    I’d second Kevin’s way using app tape and a pencil to make a template to lay over vinyl.
  • Martyn
    19 December 2017 at 15:36
    Cheers guys!
  • Martyn
    3 January 2018 at 20:17
    Hi just an update as promised. So did the van just after xmas, went with the design line 3m tape in the end. Had a bit of trouble on the long side as i laid it wet (1 man job) and heated it along the tape line but it was difficult to get the line to begin cutting into the vinyl. Obviously dry over this tape is the key.
    All in all happy with the result as was the customer.
    8 January 2018 at 18:27
    looks good!!! I’d do it dry to be honest, usually I’ll buy in a few mtrs of decent air release wrap to do such a job if there’s any kind of curves there, sounds lazy but it’s so much quicker and the vinyl is easier to work with than straight cad films.
  • Richard Urquhart
    8 January 2018 at 23:17
    Design line is a winner just remember it is a little more fragile so when pulling the filament take care but the stuff is brilliant
  • Richard Urquhart
    8 January 2018 at 23:19
    This was done with 3m cast [emoji12] but fitted with clear app tape you get no bubbles also I only used fine line on this one
  • Martyn
    9 January 2018 at 06:04
    yes dry would have been ideal but i used avery 700 and didnt want to risk it with handling best part of 3m on my own.
    I did notice the filament was fragile but was ok once you get it started
