Home Forums Sign Making Discussions Vinyl could someone help I.D this vinyl
  • could someone help I.D this vinyl
    Posted by David Mitchell on 7 June 2016 at 15:29
    as per attached photo.
    its obviously Avery , its not the semi gloss stuff that i can get easily, and it comes in 600mm rolls as the other vehicles seem to have joins in them at around that height.
    and also if anyone can have a stab at the two shades of blue, big work if i can get it , and want it to match .
    David Mitchell replied 9 years, 5 months ago 3 Members · 4 Replies
    7 June 2016 at 16:50
    Not sure on the vinyl but the joins at 600mm may just be because the original conpany only had a plotter capable of cutting 610 vinyl.
    Perhaps Avery 700? Not sure if avery print the series and colour on the backing paper, usually running up the edge of the roll.
    Ring europoint see if they can get a swatch sent out.
  • Jamie Wood
    8 June 2016 at 07:45
    Avery usually has a dot matrix code printed on the backing sheet, ie 739 PF Bright Yellow indicates 700 series.
    If you’re lucky, the sample you have may show this.
  • David Mitchell
    8 June 2016 at 09:30
    cheers lads , what i can find off the sample i have, dot matrix code
    "792"
    "ight Blue / Ref: 844080
  • David Mitchell
    8 June 2016 at 09:31
    Midnight blue it seams according to my mate google, cheers boys 🙂
