Home Forums Sign Making Discussions General Sign Topics Corner Rounder??
  • Corner Rounder??
    Posted by Rebecca on 14 January 2004 at 21:14
    Hi there
    Does anyone know if you can get a corner rounder machine (for radius corners on foamboard/correx/magnetic etc) from anyone other than Jag Sign Supplies.
    My customer is after a machine that can also punch a hole if there is one on the market.
    Rebecca
    Tim Painter replied 21 years, 11 months ago 4 Members · 6 Replies
  • Andrew Blackett
    14 January 2004 at 22:58
    Hi Rebecca,
    Suregrave do a couple of corner rounders:
    http://www.suregrave.co.uk/ancillary.htm
    Although I’m not sure whether these machines are capable of punching holes. We’ve got a punch from Machine mart, that is quite happy knocking 6mm holes through .9mm brass in one go. Maybe worth a look
    http://www.machinemart.co.uk/product.asp?p=040211116
    Andy
    14 January 2004 at 23:09
    do you know how the prices compare to jags andy?
  • Tim Painter
    15 January 2004 at 16:25
    What sort of radius are you talking Rebecca?
    If they are like the ones some print finishers use you may get a better price from a print finishing equip supplier.
  • Tim Painter
    15 January 2004 at 16:28
    Try Presco Tel: 01793 716300
    They do a corner rounder that looks better than the one in the link above.
  • Rebecca
    15 January 2004 at 23:25
    Thanks for the repiles.
    The suregrave machines look just the same as the ones from Jag, I’ll check how the price compares and give presco a ring.
    My customer deals in safety signs and is looking for holes and radius similar to the ones on the standard signs from the big safety stockists, so the size will probably vary to the size of the sign. Also the quantity we do for them can be anything upwards of 1off.
    Rebecca
  • Tim Painter
    16 January 2004 at 08:17
    Rebbeca
    Presco one is £99.40 in my catalogue Ref: 4440 comes with a 6mm radius die.
    Other dies cost £18.55
    Ive also just discovered you can fit a 6mm hole punch die to it aswell.
    Hope this helps.
