Home Forums Software Discussions Corel Software CorelDraw X4 Colours
  • CorelDraw X4 Colours
    Posted by Nicholas Gormley on 11 August 2009 at 12:07
    hi
    I Have corelDraw X4 and a roland SP-540, some of the colours on the screen come out different on the printer and I am wodering how do I correct this problem? Any help greatly appreicated.
    Nicholas Gormley replied 16 years, 4 months ago 5 Members · 9 Replies
  • 9 Replies
  • Chris Windebank
    11 August 2009 at 14:27
    The colours on screen, are they corel colours or have you imported the Roland swatch. The swatch is important as is a pantone chart.
    Never go by monitor colours
  • George Elsmore
    11 August 2009 at 14:29
    read all the way through this thread it may help
    http://www.uksignboards.com/viewtopic.p … sc&start=0
    G
  • Nicholas Gormley
    11 August 2009 at 15:03
    I think they are Corel colours? How do i download the roland swatch or how do i change to it??
  • Chris Windebank
    11 August 2009 at 15:11
    are you using versaworks? if so on the disc
  • Nicholas Gormley
    11 August 2009 at 15:28
    Aye im using Versaworks but i downloaded the latest version about a month ago.
  • Tim Painter
    11 August 2009 at 15:30
    Calibrate you work flow and create profiles.
    Is your monitor correct and your printer out, or is you printer correct and your monitor out?
    Obviously your output wants to match a swatch as close as possible but you do need a monitor setup at least close.
    If you don’t have your monitor setup how can you tell if the file is correct or way off?
    11 August 2009 at 16:07
    we use PDF method of transferring files to our RIP, to us it gives more ‘correct’ colours to what is expected, the screen is only as good as the choice of monitor. We find it to be 95% colour accurate.
    You might find illustrator looks better and corel has a slight flatness to the way it draws the screen… its all about profiling.
    We use mimaki so cant comment on roland/versaworks
  • Chris Windebank
    11 August 2009 at 16:26
    Dave, 95% is very good, Profiles for versaworks are very good and printing pantones I have found good too. I save everything to eps to print but any problem files go to PDF with no problems.
    Nick, can you get the profiles and spot colours from Roland?
  • Nicholas Gormley
    11 August 2009 at 17:12
    How do i do this?? Im pretty new to all this and still finding my way.
