Home Forums Software Discussions General Software Topics CorelDraw to SignPal problem
  • CorelDraw to SignPal problem
    Posted by Jlaulis on 8 August 2009 at 19:58
    I created a store front window in CorelDraw x3, the store name is arched both top and bottom with a logo in the middle. I saved the design in EPS and opened it in SignPal. The center design cuts fine but the arched name cuts over and over again the same lines. It will cut the letters 8 or 9 times. I have went back and checked for additional layers or lines, nothing there. I’m thinking when a arch the lettering in Corel it converts it for some reason tricking Signpal that it’s layered.
    Anyone have a fix for this or something a should try?
    John Harding replied 16 years, 3 months ago 2 Members · 2 Replies
  • Ian Muir
    8 August 2009 at 23:43
    no idea but you could try converting to curves if it isn’t already, breaking it apart,try it, then combining or welding some of it again,.. not scientific reasoning but maybe fiddling with it like this will cure your problem .. I cut with a fill and no outline but I know many cut using hairlines instead as a cutting path.
    Ian :lol1:
  • John Harding
    10 August 2009 at 08:18
    As ian said – this should cure the problem – also point of etiqette placing a post in the say hello section will pay dividends 😀
    Hope someone gives you a scientific explanation
