Home Forums Software Discussions Corel Software Corel x5 wont send to cutting master 3
  • Corel x5 wont send to cutting master 3
    Posted by David Mitchell on 7 April 2014 at 13:51
    as the title says when i try to send cut lines to CM3 it says cant cnnect to coreldraw ??
    any ideas 🙁 it wprked last tiome, ive tried reinstalling
    Hugh Band replied 11 years, 8 months ago 2 Members · 4 Replies
    18 April 2014 at 14:29
    I get this same thing more often than I like.
    Usually I have to re-install. Sometimes just restarting your PC will make it work.
  • Hugh Band
    19 April 2014 at 11:02
    I get intermittent problem with connection to our ce5000-60, sometimes pc sees it (using Corel X5 – still!), sometimes it doesn’t! have changed USB lead with no joy. Connected direct to pc not through powered hub. As with Jill sometimes reboot and all ok!
    We’re still on cut master 2 anyone know if its poss to upgrade to 3 or if its worth doing so, or if upgrade causes any problems?
    All the best, Hugh
    19 April 2014 at 16:59
    When this last happened to me, I just went to Graphtec’s site and downloaded their newest version of Cutting Master.
    I hated it! I was glad I saved the old .exe version.
  • Hugh Band
    19 April 2014 at 21:24
    Hi Jill,
    So did you go back to CM2 from CM3? CM2 does all we need it to and am a big fan of ‘if it aint broke don’t fix it’ school of thought. Just wondered if CM3 was found to be more stable.
    All the best, Hugh
