Home Forums Software Discussions Corel Software Corel X5 fountain fills following curve of text
  • Corel X5 fountain fills following curve of text
    Posted by Ron Waite on 2 February 2011 at 03:54
    How do you keep fountain fills on the same path as curved or arched text.
    Thank you
    Ron Waite 😮
    Chewy replied 14 years, 11 months ago 4 Members · 5 Replies
  • Ron Waite
    2 February 2011 at 04:09
    Here’s another example
    2 February 2011 at 08:54
    Place text on screen (Straight)
    Add fountain fill
    Convert to curves
    Add envelope
    Break curve apart
    Adjust fountain angle of each letter
    A bit crude to be honest
    or
    Create text and envelope to shape.
    Create rectangle which will be bigger than the text
    Give fountain fill to rectangle
    Use mesh fill to shape the fountain
    Place text over rectangle, you may need to alter the mesh of the rectangle to follow the text shape
    Select rectangle and powerclip into text
    Alan D
    2 February 2011 at 09:49
    thanks Alan
    i do like that sort of stuff shame the British business people don’t.
    offered similar on a few occasions and turned down.
  • Ron Waite
    2 February 2011 at 16:54
    Thank you Alan, if you ever find something easier please post.
    Ron 😕
  • Chewy
    4 February 2011 at 07:14
    Hi Ron,
    A third option will be to blend two vectors shaped to the curve you want your gradient. Make sure you have enough steps to create a smooth gradient.
    Then powerclip the result into the lettering.
    Quick and easy to edit.
    Hope I explained that clearly enough!?! 🙂
