Home Forums Software Discussions Corel Software Corel X4 Fitting text inside a circle
  • Corel X4 Fitting text inside a circle
    Posted by Jason Middleton on 10 March 2011 at 12:42
    I can’t remember how I fit the text inside the circle so that it reads the right way, I can can get it to fit to the outside of the circle but only upside down, can somebody advise what I need to do
    Many thanks in advance
    Jason
    Jill Marie Welsh replied 14 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tim Painter
    10 March 2011 at 12:46
    Do you mean following the outline or inside the circle as a container?
  • Jason Middleton
    10 March 2011 at 12:52
    Sorry yes following the outline
    select txt, then on the menu bar…. text > fit text to path, click on path and away theee goes,
    remember it’s important which way the circle was drawn, the text follows the path, once on the path there are options to sit the text on or under the line etc.
    Hugh
  • Jason Middleton
    10 March 2011 at 13:11
    Thanks Hugh but I can still only get it fitting to the underside of the circle
  • Tim Painter
    10 March 2011 at 13:16
    Should be an option to ‘Place on other side’
  • Jason Middleton
    10 March 2011 at 13:27
    Thanks, I needed to mirror vertically and then mirror horizontally
    Thanks again
    10 March 2011 at 13:34
    Look for the little "A" in the menu bar when trying to fit text to path, it lets you flip it up or down.
    In Corel 12 at least.
    It’s a real pain in the patootie.
    Love…..Jill
