Home Forums Software Discussions Corel Software Corel X4 / Finecut problem
  • Corel X4 / Finecut problem
    Posted by Colin Crow on 5 March 2010 at 18:34
    Have just developed a problem with X4 when sending through rasterlink to mimaki CJV30. Although the cut is perfectly registered in the file when I send to RL4 the the CJV cuts approx 10mm off in both X and Y axis.
    I dont have this problems on other PCs so have eliminated a printer problem.
    So far I have Restored the default X4 workspace, uninstalled and reinstalled finecut software and workspace icons, checked all options in finecut/rasterlink plug-in, rebooted everything.
    Has anyone else had this problem or could give a clue where else to go?
    Colin
    David Rowland replied 15 years ago 5 Members · 6 Replies
  • andy o'reilly
    22 March 2010 at 13:17
    Hello Colin,
    I know exactly what this is because it happened to me.The layers in Coreldraw X4 have become unaligned.I reinstalled X4 to sort out the problem.
    Andy
  • Colin Crow
    22 March 2010 at 13:24
    Hi Andy
    Thanks for replying. I tried everything else to no avail and eventually did a complete X4 reinstall and as you say it cured the fault. Still not sure what caused it although I do remember X4 falling over once when trying to send a complicated file to RL
    Colin
  • bmw_ante
    21 October 2010 at 12:57
    quote Colin Crow:
    Hi Andy
    Colin
    I have had this same trouble with Corel 12 and X3 , Somebody that know why this occurs ?
    In my case nothing would fix this, reinstalled both corel and finecut but same problem, Tried to cut trough Illustrator and this worked fine… I created a new user in windows and installed finecut , Now it cuts ok again
  • Colin Crow
    26 October 2010 at 08:42
    This has happened again on two different PCs and as you say, a complete reinstall has not solved the problem.
    I will try a new user install to see if this cures the problem.
    Has anyone attempted to install Rasterlink with Corel X5 yet?
    Colin
  • pauldodd
    5 November 2010 at 22:30
    this also happened to me on mac. with finecut
    is a new install best?
    5 November 2010 at 22:35
    X3 and text in a file… i transferred a corel x3 file between PC’s only to find that my cutter did cut the job around 10mm out for the text of the job.
    Font issue… it was rotated 90degrees and one corel decided to output it differently then the other…. never had that before.
