Home Forums Software Discussions Corel Software Corel x3 help
  • Corel x3 help
    Posted by Neil Bainbridge on 10 January 2012 at 07:08
    Morning
    I need help rounding off the corners of a rectangle, I have got a rectangle and I go to the node tool and I drag the corners in and this rounds them off but it does not
    Do them even! It works ok on a square fine
    Is there a setting I can change to overcome this? I hope this makes sence!
    Thanks Neil
    Alan Drury replied 13 years, 11 months ago 4 Members · 4 Replies
  • Glenn Sharp
    10 January 2012 at 08:08
    Neil….I’ve found Corel does this once you tweak the shape of the rectangle. If you draw a shape on screen and then immediately round the corners it seems to do them evenly….once you change the size of the rectangle it seems to distort the corners for some reason
    My work around for this is to draw the rectangle or square you want by stretching and scaling until it’s the correct size and then using ‘snap to objects’ draw another rectangle on top of your original……..because you haven’t stretched this one it should round the corners with no problems
    I’m pretty sure this was covered before and there were a few alternative ways but this has always been the way I’ve got round it
  • George Elsmore
    you should use the shape tool to radius the corners
  • NeilRoss
    10 January 2012 at 08:13
    Neil – I’m guessing what you’ve done is this:
    Drawn a square (or a rectangle) using the Rectangle tool.
    Then stretched it in ONE direction
    Then used the Shape tool to move the corner nodes to create the radius corners?
    That’s just how Corel works as far as I can make out. You need to create the rectangle to the dimensions or proportions you want the finished rectangle to be. Then use the shape tool to create the radius corners – works perfectly. Not very logical I agree. If you want to change the dimensions of the rectangle in one direction only following this then you’ll need to start from the beginning again (in my experience). Pretty annoying until you are aware of it in advance then you can think ahead and handle it this way.
    10 January 2012 at 08:32
    This was a problem with distorted rectangles but was addressed in X5 and is now fixed (not that it was a bug in the first place) a fix is as described by the guys before although there is a macro which will correct the corners and still leave the rectangle a rectangle as opposed to a curve, it is either at macromonster.com or Oberonplace.com but I can’t remember which.
    Edit http://macromonster.com/index.php?mod=d … &Submit=Go
    Alan D
