Home Forums Printing Discussions Roland Printers Corel Vs. VersaCamm
  • Corel Vs. VersaCamm
    Posted by Fredrik on 16 August 2004 at 11:33
    Hello everyone,
    I have a problem with the colors in Roland Colorrip doesnt match up with the original colors in CorelDraw 9. Im using cmyk in corel but the color aint the same in colorrip. I have been looking around in CorelD but i cant find anything that would cause this problem.
    Do you have any suggestions what i should do or look for?
    Best regards,
    Fredrik
    Rodney Gold replied 21 years, 3 months ago 3 Members · 4 Replies
  • Pryam Carter
    16 August 2004 at 20:24
    If you are exporting as an eps file it depends what boxes you have ticked.
    Can’t remember the correct settings of the top of my head.
  • Rodney Gold
    17 August 2004 at 04:10
    You are working in RGB space , Ie your monitor is displaying colours that can’t be printed as RGB is essentally an additive system (R+G+B = white) whereas the printer is a CMYK device (C+Y+M= black)
    The machine will use a swop type of algorithm to print these.
    Firstly , use color management in Corel to emulate professional output (should be under tools , color management)
    2ndly , rgb bitmaps should be changed to CMYK , all you do is select the bitmap , click bitmaps in the menu and then hit mode , change it to cmyk. You can also convert vector graphics to a CMYK bitmap(barring the cutlines)
    and export to EPS
    Should you want a WYSIWYG (what you see is what you get) scenario , you will have to calibrate the monitor to the printer.
    The rip itself (upgrade to version 2.1 , at http://www.rolandgg.com) will show you what you are getting , IE the picture colours you see is more or less what the printer puts out (if your monitor is reasonably calibrated ) , you can demo this by selecting the colour correction curves and modifying one , the pic in the box next to it will show what you are getting.)
    Go to the american Roland site , http://www.rolandgga.com and download the chip chart from thier support site and print it , then go to http://www.pantone.com and under support (i think) is a full EPS of pantone colours , print that too. That will give you a reference as to how various colours print and you can match to that in corel if you want , using either the CMYK palette or the Pantone one.
    A lot of factors will affect printing colour , like ink laydown , dot size , media etc.
    Stuff like a JPG etc doesnt have to go thru Corel to print , you can bring it directly into the RIP.
    You can export to RGB in eps rather than CMYK , however this will give a ton of error messages in the RIP , but will still print.
    Color management is one area that is fraught with difficulty , the RIP itself has a zillion options apart from your design package.
    It’s almost impossible to diagnose where your problem lies unless all the variables etc are known , IE is it an overll thing , does it affect bitmaps more than vectors and so forth.
  • Fredrik
    18 August 2004 at 21:08
    Downloaded the 2.1 and the chip chart so now im going to make the best of it.
    btw, I think the monitor is to old to be calibrated to perfection so im on a mission to make the boss buy me a new one, another question for you is,
    what kind of speccs do you prefer on a computer that works with a VersaCamm?
  • Rodney Gold
    19 August 2004 at 03:33
    In terms of the best puter , you have 2 sections to look at
    1) graphics performance – IE something that works well with your design package- that means a decent graphics card and monitor
    2) RIPPING – this requires processor power
    I would say a 2.4 gig p4 , a nice graphics card , 120mb HD , 1 gig ram , a 17″ flat screen monitor would do you nicely.
