Home Forums Software Discussions Corel Software corel print merge can i make an eps file from it?
  • corel print merge can i make an eps file from it?
    Posted by Mo Gillis-Coates on 10 May 2011 at 13:53
    Hi guys, doing some numbered decals for a customer, I have managed to follow the tutorial to use the print merge, but I don’t know how to export it to an eps file to use with versaworks so that i can mark print laminate and cut?
    Anyone please? I’m stuck on this job
    BigMo
    Mo Gillis-Coates replied 14 years, 7 months ago 2 Members · 2 Replies
    10 May 2011 at 14:23
    Print to pdf using something like cute or is you must use eps try printing to the ‘Device independent Driver that comes with Draw. I would expect Versa to work with postscript files ok, if push comes to shove just import the ps file back into Draw and export as eps from there.
    Alan D
  • Mo Gillis-Coates
    10 May 2011 at 14:27
    cheers alan, but I think i sorted it, I managed all the print settings in corel and chose versaworks as the printer, when I printed it sent all the labels to versaworks as one document and in cdr format…. added my crop marks and adjusted the settings as I normally would in the RIP, it’s just printing now I will let you know how it comes out…
    Fanx
    BigMo
