Home Forums Software Discussions Corel Software corel increasing memory help please
  • corel increasing memory help please
    Posted by Cheryl Smith on 17 February 2010 at 12:28
    Ello Everyone…. thanks for taking a mo to look at this…im sure the answer is simple but I dont know how…
    I am getting this error message….
    Virtual memory is running low.
    Please free up some memory by
    increasing the amount of free disk space by on the swapfile drive or
    increasing the virtual memory limit in windows system properties settings….
    I know I have plenty of memory on my c drive and tonnes and tonnes of memory elsewhere…
    how do I go about what it is required???
    much thankness
    Cheryl
    Cheryl Smith replied 15 years, 10 months ago 4 Members · 17 Replies
  • 17 Replies
  • Harry Cleary
    17 February 2010 at 12:34
    Have a look here Cheryl, I think Phil Barnfield’s advice worked for me.
    http://www.uksignboards.com/viewtopic.p … y&start=10
  • Cheryl Smith
    17 February 2010 at 12:37
    thank you Harry…ill give it a go xx
  • Cheryl Smith
    17 February 2010 at 12:43
    did you lose all your blue in your tool bar??? mine has gone all grey 🙁 I hope i have done it correctly….probably best to restart.
  • Harry Cleary
    17 February 2010 at 13:17
    quote Cheryl Smith:
    Nope…I did change the carpet and hung a few picturs though 😀 😀
    17 February 2010 at 14:02
    When Corel starts misbehaving a F8 restart with default workspace normally clears things. Save workspace first if customised. Not seen a virtual memory message for years though.
    Alan D
  • Cheryl Smith
    17 February 2010 at 14:59
    Hi…seems to be going okay…no idea why this started messing…ive loads and loads of memory….now ive had to sacrifice my lovely blue settings in xp 🙁
  • Harry Cleary
    17 February 2010 at 15:19
    Can you not set to default (blue) in the Appearance tab ?
    Control Panel>Display>Appearance> default(blue)
    Should fix it.
  • Cheryl Smith
    17 February 2010 at 16:32
    I think it is corel playing up as Alan says…It is shutting down saying something like abnormal termination or something….gunna do the F8 thing and try that…put everything back to how it was before…..
    I LIKE blue!!
  • Cheryl Smith
    17 February 2010 at 16:49
    Im just going to uninstall and reinstall stupid Corel…. (:) (:) (:) (:)
    im not all mad or anything…
    Just being mature about it 🙄
  • Harry Cleary
    17 February 2010 at 16:55
  • Cheryl Smith
    17 February 2010 at 16:56
    funny….corel isnt on my add or remove programs list…….. 😮
  • Harry Cleary
    17 February 2010 at 17:21
    I think if you install it again it will overwrite anything that is there Cheryl. Something has gone pearshaped if it isn’t showing.
    17 February 2010 at 18:03
    I assume F8 restart of Corel didin’t work. An uninstall and reinstal is a last resort.
    Alan D
  • Cheryl Smith
    17 February 2010 at 18:25
    To be honest Alan…I dont know how to do a F8 restart!
    17 February 2010 at 19:00
    put yer fingy on f8 when corel is starting
    doing an F8 restart of Draw. Make sure Draw is closed, hold down the f8 key and keep it down while you restart Draw. Keep it down until you get an option to reset Draw to factory defaults.
    18 February 2010 at 08:22
    As Peter says. The workspace in Corel gets corrupted sometimes, difficult to say by what but I notice it mainly after importing files from others that have repeatably crashed Draw.
    The symptom is usually Draw failing to import some other file types or just generally miss behaving – things just not working as expected.
    Solution is to restart Draw with F8 pressed and accepting factory defaults when prompted.
    Draw has the feature of being able to add your features you use all the time onto the toolbar on the left or/and on the top bar thus saving having to goto options which maybe under tabs. This customised workspace can be saved/exported, obviously you would lose this with an F8 start but it can be reloaded afterwards providing it was saved first. Same applies to any custom paletts. Macros which have an icon on your toolbar will be saved but shortcuts to them will not.
    Hope this clarifies.
    Alan D
  • Cheryl Smith
    18 February 2010 at 22:15
    Thank you everyone… really handy to know cos corel does like to faff about sometimes….
