Home Forums Sign Making Discussions General Sign Topics Corel Draw Cut Contour Help
    20 February 2019 at 10:56
    copy the image make it as dark as possible , convert to black white, or 8 bit gray then trace it, delete middle bits. is one way not necessarily the best.
    20 February 2019 at 11:17
    As Chris says…
    Bitmaps> convert the png to bitmap
    Bitmaps> Mode > black and white In dialog box select line art and adjust image until mostly black.
    Trace bitmap > line art > ok.
    Select object and break apart or remove white areas/ nodes, add outline and remove fill. You may want to bring in the outline in a mm or two to allow for edges.
  • Chris Windebank
    20 February 2019 at 13:12
    simply trace as outline low quality
    move to one side, object/shaping/boundary
    and there is your outline
  • Jonathan feeney
    20 February 2019 at 14:39
    Thanks guys , that worked no problem but i now have a new problem :awkward: the outline isnt recognising in versaworks any ideas ?
  • Chris Windebank
    20 February 2019 at 14:42
    if it was my one was just magenta as done on office PC
    copy and paste a new one and re-save and make sure its front of page
  • Jonathan feeney
    20 February 2019 at 15:19
    Got it all sorted now thank for everyones help much appreciated :smiles:
