Home Forums Software Discussions Corel Software corel bleed
  • corel bleed
    Posted by Chris Windebank on 18 March 2014 at 15:39
    used to doing business cards but this has me going mad.
    added 3mm bleed all round as usual with crops but sizing exact size as card and shows no bleed.
    Must be missing a check button somewhere and cannot remember how to resolve, any ideas?
    Chris Windebank replied 11 years, 9 months ago 3 Members · 5 Replies
  • Gary Birch
    18 March 2014 at 16:09
    Are you meaning the prepress settings in publish to pdf?
    Gary
  • Chris Windebank
    18 March 2014 at 16:16
    yes, re-booted and still the same.
    There is an image with fade across the card. Just converted to bitmap and better
  • Chris Windebank
    18 March 2014 at 16:18
    Update, problem solved. Fade needed to be converted to bmp
    Having one of those days!
    Thanks for the help Gary
    19 March 2014 at 09:47
    I usually publish to pdf using pdfx1a option and this normally sorts any transperancy and lens issues when doing litho artwork, always flatten completely for digital though or if importing into another programme (including Draw)
    Bleed – if publishing to pdf
    settings – Pre press tab – tick bleed and set required amount
    If printing to cutepdf (or similar)
    Print – layout – tick bleed limit and set required amount
    Export to EPS – advanced tab – Bounding box PAGE – tick bleed limit and set required amount.
    I have found that many trade printers prefer pdfx1a but eps seems better for many digital rips that said alot of trade printers put your files into their programme of choice for batching purposes and this is where the problems seem to start so the flatter the file – the more reliable it is for everybody
    Alan d
  • Chris Windebank
    19 March 2014 at 09:53
    Thanks Alan.
    Cute PDF got me out of trouble when Corel playing up for exports
    Top info as usual
