Home Forums Software Discussions Corel Software COREL & CutPath
  • COREL & CutPath
    Posted by Chris Wool on 13 January 2004 at 10:05
    HI
    Anybody got the definertive answer why corel V10 changes the name of the cutpath outline
    one system does it the other 2 dont after closing and reopening a file the cutpath name has changed to “cutpath (1)” etc
    very anoying if there are lots of ungrouped cuts cos they have to be reset
    and the correct name is still in the custom list
    thanks in advance
    chris mrsticker
    Chris Wool replied 21 years, 11 months ago 2 Members · 2 Replies
  • Mike Antrum
    15 January 2004 at 17:31
    Hi Mr. Sticker,
    I think the problem is as follows:
    You have a spot colour set up with (for example the following) the colour set to C:50 M:50 Y:0 K:0 and the name is CutPath.
    You import a file with a spot colour called CutPath but the values for that colour are C:49 M:50 Y:0 K:0
    Corel already has a spot colour called CutPath, but it knows that it is a different CYMK value, so it knows they are not the same. Therefore it appends the (1) to the end of the name as it cannot have two different colours with the same name.
    Hope that this helps,
    Mike Antrum.
    15 January 2004 at 19:36
    thank you a good idea and will try and follow it backwards
    but all was well untill i had to do a reinstall so a file pos left behinde
    i am just about to zap the disk and start again because of several other niggling problems that all started around the same time.
    thanks for your thoughts
