Home Forums Sign Making Discussions General Sign Topics Coping with recesses and vehicle wraps
  • Coping with recesses and vehicle wraps
    Posted by Martin Armitage on 13 July 2006 at 09:20
    Hi all, I was wondering how you all deal with recesses in panels, on a course i went on recently I was told to lay the vinyl over the recess and then work in with heat and pressure, wich is fine, the question is getting rid of the trapped air – the way they dealt with this was to pre drill holes right through the side of the van. I was wondering if this is standard practice or if there is a better solution to it.
    Martin.
    Phil Halling replied 19 years, 5 months ago 16 Members · 20 Replies
  • 20 Replies
  • Adam McGuire
    13 July 2006 at 09:52
    Pre-dril holes in the van!? If you mean the indented sections around where a window would be if it were a minibus, I’d probably use a small pin to make a hole to push the air towards. (Only if I had small bubble remaining though)
    If I remember correctly, you can work the wrap into the recess and then work along the recess pushing the air towards the back of the van say, then peel the wrap back to the edges of the recess (at the back of the van) to smooth the end of the recess in. If that makes any sense? I think drilling the van is a bit of a rough ar$ed way of doing it?
    I don’t do wraps, and haven’t done one yet either, but that’s the way I’d approach it. At SignUK, Grafityp showed how well the wrap could be pulled away from the vehicle and re-fitted.
    Hope this is of some help
  • Simon Clayton
    quote martin armitage:
    Martin.
    That don’t sound right to me… i wouldn’t be happy someone drilling holes in my £20k van.
    I would just Pearce the vinyl to let it escape, (but i have never done a wrap)..
    Simon
  • Andrew Ritchie
    13 July 2006 at 10:32
    :yikes: drill the van?
    Pierce the vinyl with a pin, has to make more sense having a little white hole in your vinyl wrap, hidden in a spot that wont be seen. rather than a rusting hole in each recess on the van. 😕
    who run the course you went on?
  • Dave Bruce
    13 July 2006 at 10:56
    Hees havin a larf 😀
  • Martin Armitage
    13 July 2006 at 11:16
    I thought I might get that reaction, The recesses were well over an inch deep and with the tension the vinyl was under would it not mean the vinyl splitting when pierced with a pin
  • Lee Ballard
    13 July 2006 at 11:18
    Probably recommends to drill a hole in glass to let air escape when doing windows 😀
  • Adam McGuire
    What type of van was it? I don’t think I’ve seen one with recesses as deep as that!
  • Lee Ballard
    13 July 2006 at 11:20
    The new LDV’s are fairly deep.
  • Adam McGuire
    13 July 2006 at 11:22
    I’ve not seen the new Maxus up close, so that’s probably why! We have a VW T4 and I recon they’re quite deep….
  • Simon Clayton
    13 July 2006 at 12:14
    If using wrap vinyl it wouldn’t be under tension, as it conforms to the shape, As Adam says tease it into the recesses once heated and formed it would/should stay…
    If i were tackling it i would get some spare material and test out the best way to do it first, then once happy i would tackle the printed version.
    What course did you say it was again??
    Simon
  • Tim Painter
    13 July 2006 at 17:20
    I sure I nice sized sledge hammer could flatten the panels out to avoid the need for drilling a whole.
    Pin and the correct vinyl for the job me thinks.
  • autosign
    13 July 2006 at 17:43
    I have heard of that hole drilling method before. I wouldn’t want to do it though.
    13 July 2006 at 18:02
    drilling holes in vans I’d sooner stick pins in my eyes 🙄 which course was it ? because I don’t think you would get sign makers telling you to drill a hole in a van unless they were pulling your leg !!!
  • Ewan Roberts
    13 July 2006 at 21:31
    Hi Martin, why not cut the whole panel out and fit a window. 😀 Seriously, when i wrap i work the sides of the recess in first then the centre part and suck the air out with a hypodermic needle and syringe.
    Ewan
    13 July 2006 at 22:38
    Martin.
    I think you should ask for your money back from whoever tried to teach you this cr@p it is totally unacceptable, and if they are condoning this method, some one is in for a large bill in the future to make good the damage.
    13 July 2006 at 23:15
    Here is an old demo i did about 3 years ago…
    as you can see these are very deep recesses. i see this van to this day, still perfect!
    full demo can be found here:
    http://www.uksignboards.com/viewtopic.php?t=17578
    In my opinion, the advice was bad… hell i cant even begin to think what would happen if i said to some of our guys… “oh and by the way, when your doing those recesses, just drill the van and let the air out!” 😕
    then walk back in ten minutes later as an apprentice asks, “rob, have you got another 10mm bit, this ones going blunt?” :yikes:
    pop the vinyl with a pin, do it at the top shelf of the recess where it wont be seen by someone standing looking at the van. holes very small…
  • MartinDenton
    14 July 2006 at 07:54
    I have never done a full wrap, but I saw a spandex demonstration last year, and the guy used a plastic straw which he laid under the vinyl so it gave a vent from the recess to the edge of the vinyl, when he had got all the air out he simply pulled the straw out and was left with very little air to remove, he then used a pin to get rid of the last bit. It seemed quite neat I don’t know if anybody else has seen that method before?
  • jamesdeacon
    29 July 2006 at 09:29
    Hi my name is James Deacon and this is my first reply to a thread I have over 5 years experience in vehicle wrapping (you may have seen me on the grafityp stand at sign UK!). Never cut holes in vans – that’s for starters the air with the grafiwrap system can be pushed out after the recess has been done just ensure its in the flat section of the recess and is in a least noticeable area/colour etc I also use the straw technique and also flapping back the wrap to a corner and passing air to it.
    (mod-edit) please read board rules
  • John Simpson
    29 July 2006 at 22:32
    quote jamesdeacon:
    Hi James……………….I have had the pleasure of watching James wrapping ……..absolutely brilliant………….just wish i could afford to employ you mate.
    L J
  • Phil Halling
    31 July 2006 at 06:42
    I can only echo what everybody else has already said, If anybody working for me even thought about drilling a hole they would be looking for another job – totally unacceptable
