Home Forums Printing Discussions General Printing Topics Contour cutting problem
  • Contour cutting problem
    Posted by Ian Higgins on 11 October 2006 at 10:52
    Hi folks
    Have a problem with contour cutting on my Cadet. After it prints it is then cutting but it is about 3mm out!
    doing a load of small circles but it is terrible!
    never had the problem before, any advice appreciated
    Ian
    Gordon Forbes replied 19 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Robert Berwick
    11 October 2006 at 10:56
    Ian – your not using a new profile are you? I think theres an offset option in there which may be incorrectly set.
    Robert
  • Derek Heron
    11 October 2006 at 11:40
    hi ian just had a similar problem with my cadet
    and went through the menu
    automatically correcting misalignment of the printing and cutting positions
    seems to have done the trick
    if you need the step by step instructions i can send them to you
    Derek
  • Ian Higgins
    11 October 2006 at 12:02
    Hi Derek,
    Can you please send them
    regards
    Ian
    11 October 2006 at 12:25
    if the cadet 54 has a environmental check do that first before doing any adjustments as it may only require the check.
  • Ian Higgins
    11 October 2006 at 12:28
    Hi Chris,
    Already tried that one..
    Thanks though
    Ian
  • Derek Heron
    11 October 2006 at 15:43
    hi ian just got back in will post pic of the page of instructions as cant post it here hope it helps
    derek
  • Gordon Forbes
    19 October 2006 at 17:04
    I reckon you need to get into the service menu and do it properly from there. I found the menu command at best useless. Got a tech to do it for me and have done it myself since
    Goop
