Home Forums Printing Discussions Roland Printers Contour cut colour – roland pc600
  • Contour cut colour – roland pc600
    Posted by Catia Merritt on 31 August 2009 at 20:46
    I have Roland pc600 loaded the new corelDRAW graphic suite x4 and i believe i have sucessfully loaded the cut colour but roland isnt responding, i am tearing my hair out does anyone have any idea about how i can make it work???? H E L P
    Catia
    Eric North replied 16 years, 4 months ago 3 Members · 4 Replies
    31 August 2009 at 20:49
    hi catia an introduction in the ‘say hello’ forum will be your best bet of getting a better response to your question 😀
  • Eric North
    31 August 2009 at 21:58
    I have some experience with roland colourchoice which I believe is supplied with your machine. My version is quite old but I hope it still works the same way. I assume you are trying to print and my version of colourchoice needs a file to work with. A number of formats can be used but the most common would be .eps format. There are others (check the import / open option ).
    In corel you have to choose to export your image. Once again there are various files you can export but one of them should be .eps
    note the directory you save into.
    After importing the.eps into colour choice you should be able to send to the pc600.
    This will send through a usb port.
    for cutting you will find a .dxf file best, I think.
    If the new colourchoice does not work this way then I wish you good luck !.
    It should be all in the instruction manual or help screens.
  • Catia Merritt
    31 August 2009 at 23:13
    Thanks 4 your advices I will give it a go….cheers!
  • Eric North
    1 September 2009 at 08:09
    something I forgot is that when I was contour cutting the width of line had to be 0.1 mm and a particular colour or something like it. Otherwise the line was identified as a print line.
