Home Forums Vinyl Cutter Discussions General Cutter topics Complete cut out? How to?
  • Complete cut out? How to?
    Posted by Oliver Holmes on 20 May 2008 at 13:59
    Hello, this is probably a really simple question… I want to produce some simple vinyl stickers straight from my cutter… i.e. I have printed them and have the outline ready to cut round them, but I was my cutter to cut them so that they fall away from the sheet of vinyl.
    I’m sure there’s a more technical term for this.
    Many thanks in advance for your help.
    Mike Robson replied 17 years, 7 months ago 5 Members · 5 Replies
  • John Childs
    20 May 2008 at 14:10
    What cutter do you use?
    Mimakis can do this, but I don’t know of any others.
  • Oliver Holmes
    20 May 2008 at 14:16
    I was hoping to do it on a Roland Versacamm SP-300…
  • Derek Heron
    20 May 2008 at 14:19
    you can do this with signlab half cut option
    derek
  • Warren Beard
    20 May 2008 at 14:20
    Summa can also do it although I have never done it before, there is a setting for it and it is a separate cut file with a higher pressure to cut through the backing paper.
    I suggest you look at the machines instructions because if it can be done it should tell you how it’s done in there.
    Warren
  • Mike Robson
    5 June 2008 at 16:14
    Bit late I know, but you can use these to stop you damaging machine. Never tried them myself, but that’s what they’re intended for.
    http://www.signwizard.co.uk/cutting_mat.htm
