Home Forums Printing Discussions Sublimation Printing Companies that produce heat transfers
  • Companies that produce heat transfers
    Posted by peterjg1972 on 8 May 2007 at 15:37
    Can anyone recommend some companies in the UK who can produce high quality heat transfers of full colour designs ( for t shirts) for use on a heat press?
    Saph-D replied 18 years, 5 months ago 7 Members · 7 Replies
  • 7 Replies
  • Richard Barraclough
    8 May 2007 at 16:08
    Sorry to jump on your post peter but ive been lookig too…….
  • John Wilson
    8 May 2007 at 16:26
    target transfers will do this
    http://www.targettransfers.com/
  • Lee Husselbury
    8 May 2007 at 22:17
    revolutiontransfers or thetransferpress any good to you!
  • Steve Underhill
    8 May 2007 at 23:12
    How big are the designs?
    as with a decent printer you can produce your own, we use an epson R1800 and xpres dark jet transfer sheets, they’re expensive by the box but if you use them a lot its not too bad
    If its a big run or you need high temperature (ie 90 deg) washing or tumble drying use target or revolution, I recently got a quote from target for some small transfers and they worked out quite cheap but will depend greatly on how many you need.
    The guy to speak to at revolution is called Jan, (pronounced yan)
    Hes very helpful.
  • nickswindon
    17 May 2007 at 20:11
    Target tend to do Plastisols which I find annoying – I Import nowadays from the US as The Transfer Press are beyond shoddy – they sent a £3000 order to a different address last month. Take my advice and buy from the US – they have a much better range.
    Nick
  • peterjg1972
    13 July 2007 at 14:47
    Hi Nick, can you recommend any US based printers?
  • Saph-D
    13 July 2007 at 14:58
    I have had some from Target Transfers, they offer a range of different papers/transfers not just plastisol, depends on the fabric its going onto and whether or not it is dye subbed etc.
    I’d recommend them any time, turn round was pretty fast too. I also print my own, depends on how busy I am and the number required. I use Targets Softjet for lights and Evolution2 for darks and had no probs. I get dye sub paper from Subli-Nation.
    Saph
