Home Forums Software Discussions General Software Topics Combining rendered and vector drawn graphics
  • Combining rendered and vector drawn graphics
    Posted by Phill Fenton on 8 December 2005 at 23:35
    I am having problems trying to represent certain layouts for my clients.
    When I wish to represent a rendered image (such as a 3d logo saved as a JPG) shown on a vehicle outline I find the logo includes a white rectangular background instead of a clear blackground. Consequently If I am trying to show a digital image in the form of a JPG superimposed on a coloured background the result includes a white rectangle directly behind the logo.
    Is there a way to create a rendered image that doesnt include a white background? Corel Draw has an option to create a “clear” background when rendering to bitmap – however this still shows up as white when superimposed on a coloured background.
    I hope this makes sense 😕 – Any advice?
    steve geary replied 20 years ago 6 Members · 6 Replies
  • David McDonald
    9 December 2005 at 00:15
    Hi Phil
    I’m not sure if JPEG file formats allow you to have a transparent background. As I recall GIF file formats do allow this option. (or they have done when I’ve designed web pages)
    Some design applications have a ‘make transparent colour option’ – ie. you identifty a colour with an eye dropper type tool and it makes this colour transparent wherever it appears.
    Failing that I design all the vectors in Flexi and export into Photoshop to use its tools to achieve your desired effect.
    Macky
  • Nancy Wannous
    9 December 2005 at 00:45
    Hi There does the file format have to be jpeg?
    If not you can clip mask the file is photoshop save it as eps that will take the background off.
    another way is if you have the file without the background in photoshop save the file as psd keep layers open in illustrator add whatever text or vector files in illustrator save as eps .
    Then print it out 😉
    9 December 2005 at 08:18
    In Corel Draw make the desired shape then ‘powerclip’ (effects) your bitmap into it. The powerclip shape can be given an outline. Giving a bitmap a transparent backgroud will only work for black and white bitmaps (applies to Draw only) If you want to use a photo editor Corel’s PhotoPaint which comes with the suite will do the same job as Photoshop. If you go the powerclip route exporting that as eps and re-importing will keep the shape.
    Alan D
  • Paul Rollason
    9 December 2005 at 09:05
    Hi Phill
    If you have photoshop, try clicking the magic wand on the white backgroung to select it, then press Ctrl+shift+I to invert the selection thus selecting the image then copy and paste.
    This will put the image on a new layer.
    now delete the background layer or just click the eye on the layer palette to make it invisable and now you have a clear backgroung (grey and white squares)
    Save as a giff and make sure the transparency box is ticked
    import into corel or whatever layout software you are using
    This works well for placing images onto websites as well
    paul r
    9 December 2005 at 16:55
    Thanks everyone for the advice.
    I have corel draw and corel photopaint. I managed to get this working using photopaint. 😀
  • steve geary
    9 December 2005 at 17:48
    the only thing i can add Phil, since i only know corel draw and photo paint is:
    You can crop the background and save with no background as a photopaint file. It will add a white backround if you open it with anything other than corel draw, or paint again. if you bring it into Draw and layer on top of vector or a j peg it will work, then you can export from draw the whole selection as a jpeg and it’ll look the way you want.
    my knowledge is limited, but that’s how i do it.
    steve
