Home Forums Sign Making Discussions Neon, LED, Lighting Coloured film to fit over floodlights
  • Coloured film to fit over floodlights
    Posted by Ewan Chrystal on 27 October 2015 at 15:36
    Last year i created this effect using normal coloured vinyl onto the floodlight glass. They want the same this year and i’m trying to find a more suitable film. The problem last time was the vinyl started to melt with the heat of the bulb. I know i can get gel sheets but these aren’t self adhesive are they? Ive tried looking for coloured bulbs but cant find any. The lights are standard floodlights with RX7s halogen bulbs.
    Any suggestions?
    Ewan Chrystal replied 10 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • David Rogers
    27 October 2015 at 23:03
    What about coloured glass on the inside.
    28 October 2015 at 02:18
    If you can get something suitable that isn’t self adhesive you may be able to make it self adhesive using a print mounting film, I do this with quite a lot of materials that I need to stick to something.
    How many do you have to do Ewan? How much mount film would you need for the job??
  • Ewan Chrystal
    28 October 2015 at 08:16
    Only 2 to do, approx 200X200 each. I think I may have found red LED replacement bulbs . Need to check the size today
    28 October 2015 at 08:23
    You should be able to get LED Lamps with just about any fitting these days but they may not be as bright. If you do end up needing a bit of D/S mounting film I have optically clear film & can put a bit in the post for you Ewan.
  • Bob Scullion
    28 October 2015 at 08:48
    Ewan
    Hexis have a good range of coloured films, not sure how it would be with the heat though, they will send you 2 or 3 samples free of charge.
    Oracal also do the 8300 coloured range, commonly used for tinting car lights
    Bob
  • Vic Adair
    28 October 2015 at 12:36
    Forget the name of the film we used in the theater but if you contact either your local Theater and ask the Lighting crew or try somewhere like Tandy, as they sell disco lights.
    Its not a sticky film.. There you go lol
  • Ewan Chrystal
    28 October 2015 at 15:33
    Thanks for the suggestions everyone. Vic that link was spot on. The film is suitable up to 220 degrees which is higher than any of "our" vinyls.
    Martin, thanks for the offer but i can attach this with high temp resistant tape.
    Will try and remember to post a photo when its done
  • Ewan Chrystal
    4 November 2015 at 09:47
    Update!
    Ordered the coloured film from stage depot and fitted over the glass using heat resistant tape. The film is rated up to 220 degrees. I put my laser thermometer on the lights and the hottest they got was 113 degrees so all good. Here’s the result. If i would change anything it would be stronger bulbs, These ones are 150w but i reckon 200 would give a better glow.
