Home Forums Printing Discussions Roland Printers colour setting in vers a works
  • colour setting in vers a works
    Posted by Lynn Wang on 18 July 2013 at 17:32
    hi
    im using versa works
    what is colour setting for printing a photo ?
    set in sign and display. am i correct?
    the photo is attached
    thanks
    Joe Wigzell replied 12 years, 4 months ago 1 Member · 1 Reply
  • 1 Reply
  • Joe Wigzell
    22 July 2013 at 16:09
    Hi Lynn,
    Unfortunately it is not as straight forward as which is the ‘correct’ setting for colour management. 😕
    Also…it is not a simple explanation! It can depend on a number of aspects such as input profile attached to image and the use for the desired output.
    I would say as a rough rule though I would use Pre-Press Europe for printing photographic images.
    You could always do a test by nesting together several versions of the same file-allocating different colour management presets to each and then printing them to see the differences.
    Hope you get it sussed!
    All the best
    Joe
