Home › Forums › Printing Discussions › General Printing Topics › Cold mornings & Versacamm
Posted by Stephen Benson on 14 July 2005 at 18:49Anybody ever run into trouble with their Versacamm on cold mornings?
Stephen Benson replied 20 years, 4 months ago 5 Members · 7 Replies -
cold mornings??????
not here at the moment!!
however, we haven’t had any probs with ours
stephen -
Dunno what type of problems you are talking about , however doing environmental calibrations first thing and then again after a while of running might help.
Do you mean the 10 minutes it takes in the “now heating” mode before it will print? 🙄 Sometimes it is hard to stay patient! -
I’ve not got a Versacamm myself but heard from a user recently that ran into a few problems early one cold morning. Apparently the ink became clogged up in a filter of some sort. No idea really what they mean but would like to understand the issue a bit better.
Says you are supposed to do an enviromental check very often fron the panel for best results
Goop
There are no filters in the Versacam , the ink goes from a cartridge along to pumps and then to dampers (little reservoirs) and then to the heads themselves. The cold wouldnt cause a blackage , leaving the heads uncapped (off the capping station where they park) might cause the heads to dry up .
Cheers for that Rodney – I’ll clarify this with the machines owner next time I talk to them. They did specifically say that ‘little filters’ had ‘clogged’. I thought myself that this was possibly because of viscosity changes due to the cold. Your information contradicts this assumption. Steve.
