Home Forums Sign Making Discussions CNC Router and Engraving CNC Wood Engraving Colour In fill HOW
  • CNC Wood Engraving Colour In fill HOW
    Posted by Fatbloke50 on 25 June 2015 at 15:01
    I have a small CNC machine I want to use to engrave wood for door numbers / house names.
    How do I colour infill the engraved text ?
    Sorry if this is a silly question but using a paint brush doesnt give a nice edge.
    roy
    Stephen Morriss replied 10 years, 5 months ago 5 Members · 5 Replies
  • Unknown Member
    25 June 2015 at 18:50
    Greg from National engravers on his forum might be able to advice on this? His done some bits for me in the past with infill in metal
  • Simon Worrall
    25 June 2015 at 20:36
    Put a piece of stencil vinyl down before engraving, and cut through both the stencil and the wood.
    Then fill in as normal and remove stencil.
    Simon.
  • Denise Goodfellow
    25 June 2015 at 21:20
    I can remember making a house sign in woodwork we used a liquid plastic
    25 June 2015 at 21:25
    quote Fatbloke50:
    roy
    It will if you use the right type of brush & take a bit of care, you will also need to seal the wood before painting to prevent paint bleed. Paint mask, application tape etc can be applied before carving which may also help as Simon says. You really need to invest in some proper sign writers brushes to get the best results.
    If you take the time to introduce yourself & tell people a bit about yourself & what you do you will also find you get a better response to questions.
  • Stephen Morriss
    29 June 2015 at 15:20
    We do these by sealing the surface with varnish, V bit routing, then paint the lettering and sand it back lightly on the surface and re-varnish the whole thing. Leaves nice sharp edges to the lettering etc.
