Home Forums Printing Discussions General Printing Topics cmyk black what formula to use
  • cmyk black what formula to use
    Posted by Martyn on 17 January 2019 at 13:38
    Hi all, ive always printed black using standard illustrator setting 100% k. However i noticed the its not black black and after some testing found a much better formula. C60 M40 Y40 K100. Problem is now im doing some small stickers 35mm, the yellow and black text is slightly migrating together creating rough edge and affecting the yellow edge slightly.
    What do you guys use?
    David Wilde replied 6 years, 11 months ago 7 Members · 8 Replies
  • 8 Replies
  • Pane Talev
    17 January 2019 at 13:55
    I guess that will depend a lot on your profile. Make and print these 3 and see the difference
  • Alex Crosbie
    17 January 2019 at 15:28
    For large areas of black I use 30, 30, 40, 100.
    Pane is absolutely correct, it will depend on your printer, ink, material and profile as to how much ink it lays down and the density of black that then creates.
    For smaller text revert back to 100 percent k, you won’t notice the black being slightly lighter as there’s less of it and the colours won’t bleed in to each other then.
    Alex
  • Chris Windebank
    17 January 2019 at 15:29
    for a deep black try
    100% black
    50% magenta
    50% yellow
    50% cyan
  • Cheryl Smith
    17 January 2019 at 17:16
    I use 20 20 20 100
    Cx
  • Martyn
    18 January 2019 at 05:02
    Thanks for the responses guys. i will try them all out and change it when doing small text :thumbsup:
  • Joe Wigzell
    18 January 2019 at 09:40
    What config are you using?
    With a Roland device and VersaWorks you have the Roland Color Systems Library – a set of spot colours that you can use with specific settings and in there are 2 different blacks, a 100% black ink and a composite one.
    If you use a CMYK percentage the actual values may differ depending on the RIP settings…colour management.
  • Martyn
    18 January 2019 at 10:29
    quote Joe Wigzell:
    Hi, setting up with illustrator. Onyx rip and mutoh vj
  • David Wilde
    21 January 2019 at 08:38
    I use
    20
    20
    20
    100
    HP Latex / Onyx Rip
    Sent from my SM-N960F using Signapp mobile app
