Home Forums Sign Making Discussions Vinyl cleaning windows before applying viny whats the best method?
  • cleaning windows before applying viny whats the best method?
    Posted by nick cope on 2 April 2007 at 15:52
    hi
    i have a job and its applying lettering to a bar window
    and would like to know the best way to clean the work suface and what products are best to use, and also if anybody has any of there own methods
    of preporation , i have ordered some cleaning soloution ,but it may not arrive for a week ,and also would like to know if there is something i can buy from a hardware store which will besufficiant until my order comes
    greetings
    nick
    Jayne Marsh replied 18 years, 7 months ago 6 Members · 6 Replies
  • Kevin Flowers
    2 April 2007 at 17:01
    Nick
    use meths & a scraper, check out Rob’s video demo of applying glass etc
  • Peter Mindham
    2 April 2007 at 17:24
    Yup
    Meths or I use Avery panel cleaner. Scrape at least two or three times.
  • nick cope
    2 April 2007 at 18:44
    THANKS PETE and kev for you help
  • squareone
    3 April 2007 at 04:36
    If I am doing storefront or window graphics, I use a medium size pump-up sprayer, a razor, and a window squeegee.
    First I spray the windows graphic area
    *solution One gallon water, 2tbs baby shampoo and 32oz alcohol
    Next I use the razor to scrap the glass
    *the razor will remove the solution and help you see what you scrap so you do not miss any spots.
    Last I spray the area very well, scrub it and squeegee the excess water.
    Time to lay your vinyl
    Note: I also spray this solution on my application tape and let it set for a minute. This will help the adhesive on the application tape release with little effort.
    I’m no expert but one of the first jobs I did almost three years ago still look great
    Hope it helps
    -Rich
  • Cheryl Smith
    3 April 2007 at 06:13
    to get old glue off a window I got a really good tip from a window cleaner.
    Water in a spray bottle, spray onto target window, then simply use a razor blade in a razor holder to scrape old glue off window. simple as that.
    the glue does not end up all ‘snoty’ and sticky. Its amazing and it works.
    then simply methylated spirits on a clean cloth to remove any greasy paw prints.
    cheryl
  • Jayne Marsh
    3 April 2007 at 08:11
    I do alot of window vinyl now on a repeat basis so im always taking off and replacing vinyl graphics on the same windows. I use rapid prep to clean the surface area and good old fashioned elbow grease to remove glue ( it always comes off really easily ). I try to avoid using metal scrapers because if you slip you can actually scratch the glass if you’re not careful. I even managed to hit myself in the face with a metal scraper the other day when I got too enthusiastic removing a letter, luckily it wasnt a sharp blade 😮
