Cheap A-Boards. Hinge Handle
I´ve just received samples from England of the HINGE HANDLE for making cheap A-Boards.This was discussed a couple of weeks ago, and one of the the replies was from George (Elsmore?).
He said he´d used the hinge with 5mm. PVC.
Although the hinge is a great idea, I find 5mm. is to "bendy".
10mm. does the job much better, but is a lot more expensive.
From a cost point of view, obviously I´d like to use 5mm. But is this really a practical option?5mm x 3050 x 2020 costs in Spain 158 euros (approx. 100 pounds).
This works out at approx. 10 pounds per. A-Board (plus the cost of the hinge). 10mm. PVC is almost twice the price.
First question is, how can I use 5mm. as a practical option?
2nd. question: How do the prices for PVC compare with what you pay in the UK or any other country?At the moment I can make A-Boards using attractive metal frames (one size only) in various colours for about 30 quid including 2 pieces of 5mm. x 580 x 1000 PVC which slide into the frame and can easily be reversed to display a different message on the other side.
As sign-makers, if you had these, would you stock a few Hinge Handles as well?Any opinions or advice would much appreciated.
Thanks. Chris
