Home Forums Sign Making Discussions Vinyl Chapter 8 removal
  • Chapter 8 removal
    Posted by Mike Grant on 17 December 2013 at 09:32
    Have any of you boys or girls had the privilege of removing chapter 8 chevrons and striping. Does it come off easily or is it a (hot) (:) (chat.) 👿
    Brian Little replied 11 years, 10 months ago 4 Members · 6 Replies
  • Rod Gray
    17 December 2013 at 10:09
    Many times 😥
    There is no magic bullet for this Mike, it`s all or nothing.
    Hard work and loads of elbow grease.
    You`ll waste more time looking for a miracle solution that magically makes the gum disappear etc but it doesn`t work no matter what any snake oil salesman tells you.
    We remove the outer plastic and then soften the gum with 2k thinners.
    Once the gum is softened we scrape it off using a plastic cataloy spreader.
    You won`t avoid soft scratches. You will need to polish or compound these out afterwards.
    It is basically a horrendous time consuming job and i advise avoiding having to do it completely in the first place.
    :lol1:
  • Brian Little
    17 December 2013 at 10:40
    what any snake oil salesman tells you…..your joking rod ive just bought 40,000 litres of the stuff 😀 😀
  • Vic Adair
    17 December 2013 at 13:04
    Gently warm it up, not too warm and peel off. It will most likely leave gum.
    We use RapidTac Gum remover
    http://www.rapidtac.com/rapid-prep.html
    Best way is to spray it on leave for a 30-40 secs then spray again let it soften then scrape off and repeat.
    The trouble with Thinners is obvious things like fire and smell also thinners is not very good for the skin.
    Never had any complaints with RapidTac Remover over the past 12years of using.
    Remember to wash of with water after using it.
  • John O'Sullivan
    17 December 2013 at 17:26
    quote Brian Little:
    Brian i will take 5litres off you if that helps 😕 thats if you do free delivery to ireland 😀 😀
    Mike,having done some of this type work i would agree with Vic’s removal methods but if you can side step this job completely,its slow sh*t work 😀
  • John O'Sullivan
    17 December 2013 at 17:29
    sorry double post 😕
  • Brian Little
    17 December 2013 at 19:09
    hmmm sorry john but im afraid im going the RHG route id have to charge you my freind!!
