Home Forums Software Discussions Corel Software Changing Font when its converted as a curve
  • Changing Font when its converted as a curve
    Posted by Daniel Warren on 13 April 2012 at 07:53
    I may be going a long winded way about this.
    When I create text in CorelDraw, I convert it to curves so it is easier to manipulate.
    I move it around, adjust it, distort it etc etc.
    When for example, I realise I actuallly now dislike the font, it appears too late to change it.
    Is there a way around this? Or am I perhaps starting off wrong by converting it to curves straight away?
    Alan Drury replied 13 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Dan Osterbery
    13 April 2012 at 08:22
    I always save a copy before converting to curves, then you have the option to manipulate or change the fonts.
    Dan
  • NeilRoss
    13 April 2012 at 08:32
    As Dan says, make a copy/duplicate (Ctrl + d) so that you can always revert to it. Depends on how much or what kind of distortion you have in mind. You may not need to be converting to curves – take a look at the Envelope tool for example.
    13 April 2012 at 10:02
    quote NeilRoss:
    or, quicker in corel, drag your item while holding left mouse key down, right click when in place and it’ll duplicate there and then!
  • NeilRoss
    13 April 2012 at 10:31
    No, Hugh – not for me I’m afraid – still using v12 here!!! Dinosaur alert! 😀 😀
    I like hot keys anyhow. I did a lot of tech drafting in the distant past using AutoCAD under DOS – hot-key commands abounded… can be very fast method of working once you’re used to it. I got a shot of Windows AutoCAD around a year ago – couldn’t make a bat of it ! 😕 Took me all of ten minutes to chuck it in…
  • Daniel Warren
    13 April 2012 at 12:30
    I use the envlope feature after I convert the text to curve.
    I found without doing that, the larger text box wouldn’t skew it as well as when a curve.
    I will play about with some text later uncoverted and see if I can get the same sort of results.
    Talking of dinosaurs, i’m using V11.
    13 April 2012 at 12:34
    Hi Niel,
    just checked and it works in 12 too!
  • NeilRoss
    13 April 2012 at 12:49
    quote Hugh Potter:
    Hi Niel,
    Nu – still doesn’t work in this version/config. Probably a setting for it somewhere.
    Ctrl + d = way to go! 😀
    14 April 2012 at 13:13
    Just pressing the + key will place a duplicate directly ontop of the orginal.
    Alan D
