Home Forums Printing Discussions General Printing Topics Changing dampers can cause head failure
  • Changing dampers can cause head failure
    Posted by Martyn on 23 November 2021 at 07:22
    Hi all. So its that time again when i feel the need to spend a bit of money on my mutoh vj for some tlc. Changing the maintenance station which was done nearly 4 yrs ago. This isnt something i do myself, i have an engineer out. Anyway i was hoping to get the dampers changed aswell not that theres anything wrong but i thought it as preventive maintenance and ive been told the dampers are only normally changed with head replacement as changing them could cause damage to head. This is new info to me, is anyone aware of this?
    Martyn replied 4 years, 1 month ago 6 Members · 12 Replies
  • 12 Replies
    23 November 2021 at 07:52
    First off, I do not have a Mutoh or know anything about them.
    However, when we had several Roland solvent printers I would keep stock of dampers, wiper blades, manifold etc. which allowed me to be able to do some light maintenance or problem-solving tasks, before getting a technician out.
    I am going back years now, but the damper is mounted to the manifold, holding the ink during printing and filtering it to the head. it was snug pushed onto a pin on the manifold and the head was below the manifold. (from memory)
    Based on the Rolands we had, I can’t see how that could possibly damage the head as it’s not directly in contact and changing the filter, has to be a good thing?
    dampers were not expensive and I would keep a full set in stock.
    maybe it is different on the mutoh but I would think the same principles would apply?
    23 November 2021 at 08:55
    That doesn’t sound right to me? Can you ask your technician to explain how it could damage the heads?
  • Martyn
    23 November 2021 at 09:07
    Thanks guys. yes ive got the same feeling this is a weird answer. This is coming from the salesman not the engineer. I think i need to get hold of the engineer
  • Martyn
    23 November 2021 at 11:09
    So having now spoken to the engineer….this info is correct. 4 yrs ago the dampers were changed as part of the package. Now they no longer do this due to the risks involved but the price stays the same. go figure. Maybe mutohs dampers are far superior and last the lifetime of the head 🤥im doubtful
    23 November 2021 at 13:53
    I don’t know about Mutoh’s, but I know on our old Seiko the dampers weren’t changeable and part of the head.
    On our old Roland the dampers were changeable however you had to be careful not to damage the manifold/nipple when replacing them.
    • Martyn
      23 November 2021 at 14:33
      ye thats the strange thing david, they are changeable and were changeable but now they have decided they dont want to anymore.
  • Paul Hodges
    24 November 2021 at 12:36
    Well if that is true, they better inform all the engineers I’ve ever had or spoken to!
    Changing the dampers on a Roland, or any other similar printer where the dampers are a separate consumable, is one of the first goto things to do when you have an ink problem. I’ve changed them many times on my own, engineers have changed them, never had any head problems resulting from that.
    The only reason I can think they may not want to do it, is in case the manifold breaks. On the Roland, the manifolds are just plastic and fairly often they break off when you pull the damper off the spigot, because the ink weakens the plastic and it becomes brittle and snaps, so you end up having to replace the manifold as well as the damper – still not a big job for an engineer, but going from memory, the manifolds can be a bit over priced, so you can imagine an engineer not wanting to replace that at their own cost, but I see no reason why they can’t ask you to cover that should it happen.
    If that were true that changing dampers causes damage to the heads, we would have been replacing heads all the time, and we don’t!
    • Martyn
      24 November 2021 at 13:59
      totally agree paul. Well im gonna go with it this time and interrogate the engineer when he is here
    • Paul Hodges
      25 November 2021 at 13:16
      Good idea.. I quite often find that engineers are a lot more honest with answers when they are there on site, particularly as opposed to what sales people will tell you lol
  • Martin Cole
    25 November 2021 at 16:40
    All sounds a bit suspect to me, does the salesman look like this by any chance
    • Martyn
      26 November 2021 at 12:23
      Dont they all martin?
    26 November 2021 at 09:37
