Home Forums Vinyl Cutter Discussions Roland Cutters changing an encoder strip?
  • changing an encoder strip?
    Posted by Dan Osterbery on 16 April 2014 at 08:22
    Hi Guys, i seem to be getting intermittent printing problems, and I think it is the encoder strip, we have been cleaning it, and it runs ok for a couple of hours, then the problems appear again. The encoder strip has not been changed since we bought the machine 8 years ago, it now has visible black marks running down the middle of it. I have bought a new one, has anyone changed one before is it very complicated? Its the normal drama, loads to get finished before Easter, and cant get any decent prints, so would like to have a go at changing it our selves today! Any advice appreciated.
    All the best
    Dan
    Dan Osterbery replied 11 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • David Lowery
    16 April 2014 at 08:30
    Simples! Done mine twice now…go for it.
    Take it slowly and it is very easy
  • Dan Osterbery
    16 April 2014 at 08:34
    Hi Dave, thanks for your response, i cant seem to find any instructions on how to do it, anywhere? I believe there are adjustments that need to be made in the service menu, after you have changed it? Or is it just a straight swap?
    thanks
    Dan
  • David Lowery
    16 April 2014 at 08:45
    Just a straight swap 🙂
  • David Lowery
    16 April 2014 at 08:46
    undo the spring end first and tape with application tape so you dont drop the spring lol
  • Dan Osterbery
    16 April 2014 at 12:50
    thanks for your help! Encoder strip changed, linear calibration done, and all seems well!
  • David Lowery
    17 April 2014 at 07:45
    Excellent 😀
  • Steve McAdie
    17 April 2014 at 07:53
    Dan, It should be set up in the service menu. If you have a service manual then it is there in black and white from the manufacturer i’m pretty sure they didn’t write it for nothing.
  • Dan Osterbery
    22 April 2014 at 08:07
    Hi Steve, sorry that’s what i meant when i said the linear calibration etc, yes there are two menus in service mode that must be adjusted or calibrated after fitting a new encoder strip.
    thanks
    Dan
