Home Forums Software Discussions Corel Software cdr12, contour issue
  • cdr12, contour issue
    Posted by Hugh Potter on 10 May 2010 at 20:22
    HI all,
    still using corel draw 12 here 😳 and it’s now developed a prob with the contour effect,
    regardless of whether i instruct it to add an internal or external contour, the best it does is duplicate the object behind the original, just enough to hint at a hairline behind it,
    any idea’s what might be causing this or will i have to do a reset (which i can never remember which f key to use!)
    TIA,
    Hugh
    Lynn Normington replied 15 years, 7 months ago 2 Members · 4 Replies
    10 May 2010 at 20:26
    that was quick…. 😀
    in the settings on the contour docker, the contour and colour acceleration setting had been set to negative settings, i put them back to neutral and it works fine!
    I knew someone had been on this pc…. everyone denied it and i assumed i must have opened a saved ‘unread’ pm on another forum and changed all my sound settings myself… though i knew i hadn’t! it’s either the kids of a poltergeist! hopefully not the latter as it’s now dark outside and the outside lights have packed up!!
    10 May 2010 at 20:36
    did I miss that ? did you answer your own question 😀
    10 May 2010 at 21:16
    quote Lynn:
    yup!! 😀 😀
    10 May 2010 at 21:18
    ok well done Hugh 😎
