Home Forums Software Discussions Signlab Software CDL file to EPS to JPEG
  • CDL file to EPS to JPEG
    Posted by Hayley on 7 January 2009 at 17:24
    Hi there hope someone can help me
    Quite new to sign business, have been using signlab programme and was wondering what programmes are available for change cdl files into jepeg for email to customers, at the moment im exporting it to abode illustrator as a eps then saving as a jpeg i wondering if there is an eaiser way?
    many thanks
    mod-edit please post in correct forum
    this has now been moved
    Steve Morgan replied 16 years, 11 months ago 4 Members · 5 Replies
  • Brian Hays
    7 January 2009 at 17:34
    A newer version of Signlab. Signlab is the only program that will read a Signlab file.
    Or you can pull the job up on screen, press the "print screen" button on your keyboard. Then open windows paint & go to edit & paste. You will then need to crop the image to remove the signlab icons, menus etc.
    Wrong forum btw, this post may be moved! 😉
  • Steve Morgan
    7 January 2009 at 17:49
    If you have a fairly recent version of SignLab, I think 7.xx onwards, you have the option to export as a Pdf file, which if it’s purely for viewing purposes is as easy as sending a jpeg and can be opened using the free version of Adobe Acrobat, which may even be easier for most customers especially if they are not trade based. – there is also the option to prevent the file being edited or even printed by the recipient which can make you designs a little more secure.
  • Lorraine Clinch
    8 January 2009 at 09:09
    quote Steve Morgan:
    ……. Adobe Acrobat, which may even be easier for most customers especially if they are not trade based. – there is also the option to prevent the file being edited or even printed by the recipient which can make you designs a little more secure.
    Hi Steve, I use PDF all the time but didn’t know you can prevent printing-how do you do this?
    Sorry Hayley to hi-jack your thread. What version of SL are you using? You can also use the ‘export image’ button under ‘file’, but can’t remember if this is only on later versions…
    Lorraine
    8 January 2009 at 09:38
    Lorriane
    there is a check box that needs ticking when the pdf dialogue box opens,
    you can even password protect it. preventing print isnt really secure, a screen capture gets around that.
    If sending PDF it is still better to convert to a jpg though, as then the vectors are not available for copying
  • Steve Morgan
    8 January 2009 at 09:44
    Lorraine,
    Exactly as Peter says.
