Home Forums Software Discussions General Software Topics cant remove or reload autocad
  • cant remove or reload autocad
    Posted by Micheal Donnellan on 5 October 2006 at 13:32
    Since I lost my external drive a while back I have had several problems. The latest is Autocad 2006. It was installed on the drive that had the head crash. I get the message "error 1327 invalid drive k:/" K being the drive that failed. I cant install from disk as says its installed already. I need to use AutoCad now. So hoping praying that you can help me with this one.
    Nick Minall replied 19 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Rogers
    5 October 2006 at 13:55
    You tried uninstalling it through windows ‘add/remove programs’?
    It’ll probably just be info in the registry hanging around – if you have a reg cleaner it might get rid of it.
    5 October 2006 at 13:59
    might help
    http://discussion.autodesk.com/thread.j … dID=494347
  • Micheal Donnellan
    5 October 2006 at 16:31
    Went mucking about with registry finding autodesk and changing K: to C:. no luck still cant get it to reinstall/repair or remove autoacad. most help on net is to rename a misnamed drive, that don’t work when you drive is a lump of metal.
    With reg cleaners, how easy are they to use and do you recommend any?
  • Nick Minall
    5 October 2006 at 16:35
    The problem is that windows still thinks it installed, you need to convince it that its not there 😕
    Is there not a option to repair/reinstall in add and remove?
  • Micheal Donnellan
    5 October 2006 at 17:00
    Repair and reinstall do not work, the same error is generated.
  • Nick Minall
    5 October 2006 at 17:04
    you need to delete all things autoacad, folders and reg stuff.
  • Nick Minall
    5 October 2006 at 17:09
    Have a look here
