Home Forums Printing Discussions Roland Printers cant do sheet cutting
    13 April 2013 at 14:58
    its telling you to remove the metal media clamps.
    if you have removed them then the eye on the head thinks they are there so won’t allow the printer to do the cross cut.
  • Lynn Wang
    14 April 2013 at 00:22
    hi
    thanks for the reply,
    after printing, the clamp is removed. i hardly put the clamp .
    is there any option about the sheet cutting in versa works?
    thanks
  • NeilFox
    14 April 2013 at 14:18
    Lynn,
    Open the settings for your job in Versaworks and go the the Printer Controls button. Under ‘General’ (top Left) you will see ‘Cut sheet after output’ Check the box and you should be good to go.
    Neil
