Home Forums Printing Discussions General Printing Topics CANON W8200 PRINTER + PC WONT TALK TO EACH OTHER
  • CANON W8200 PRINTER + PC WONT TALK TO EACH OTHER
    Posted by Richard Barker on 25 May 2006 at 19:33
    hi
    i have just bought a Canon W8200 but i cant get my pc to talk to the printer.
    i have just done an ipconfig on my pc and i have the ip address, the submask and the default gateway.
    when i put these values in the into the printer it will not print.
    i have tried a ping test which i got no joy.
    the printer is connected to my pc via an ethernet cable and i run windows xp.
    can anyone help?
    Richard Barker replied 19 years, 7 months ago 4 Members · 15 Replies
  • 15 Replies
  • Aitor Asencor
    25 May 2006 at 20:44
    what kind of cable are you using? parallel?
  • Richard Barker
    25 May 2006 at 20:46
    its an ether cable that i used to use for my router to connect to my pc
  • Pauly
    25 May 2006 at 21:33
    Make sure your rip is set to communicate with the IP address of the machine (ie: put in the IP address of the canon into your RIP software), if you have done this, then, depending on your setup, if you havent already, try setting your Default gateway on the canon to the same address as your canon IP address. Generally, depending on your setup, your subnet mask should be 255.255.255.0
    Please give some more information if this doesnt help, and i may be able to assist in more detail.
  • Aitor Asencor
    25 May 2006 at 21:37
    If it’s connected directly you may need a crossover cable.
    The cables used to connect to routers are parallel.
    A- Check the manual if you need a crossover cable
    B- if not, check if your cable is ok.
    Network guide for w8200 in pdf:
    http://downloads.canon.com/cpr/software … _W8200.pdf
  • Pauly
    25 May 2006 at 22:39
    If its connected directly, you will definitly need a crossover cable.
  • Richard Barker
    25 May 2006 at 23:05
    hi
    if i look at both ends of my cable side by side the wires are in the same order.
    i have just looked at this link
    http://en.wikipedia.org/wiki/Image:Verg … rkabel.gif
    and as you can see the wires are not in the same order. so i guess i have the wrong cable?
    thanks
  • Pauly
    25 May 2006 at 23:22
    Sometimes it a bit hard to tell, but yeah, it certainly sounds like you need a crossover cable, but only if your canon is plugged directly into the machine your running it from, if its going through a switch, then your current cable is whats required.
  • Richard Barker
    25 May 2006 at 23:35
    ok thanks
    i think that may be the problem…
    i have linked my pc direct to my printer
  • Richard Barker
    26 May 2006 at 19:04
    hi
    i have now bought a crossover cable and i am still not getting the pc and printer to talk to each other.
    i have done an ipconfig in command prompt and found my ip, subnet mask and default gateway.
    i have put these values into the printer.
    i have been told to change the last digit of my ip when i put the value in the printer. so my ip ends with the number 3 so i have put the number 4 in my printer.
    any more ideas as i am getting a bit fed up now
  • Aitor Asencor
    27 May 2006 at 07:53
    You said you got a router, why don’t you use it?
  • Jamie Wood
    27 May 2006 at 08:23
    Have you got the correct drivers for your RIP?
  • Richard Barker
    27 May 2006 at 17:45
    hi all
    many thanks for the advice.
    i am a complete novice to this printing lark and the printer has been bought for my partner. She wants to print photo images to canvas in her spare time as a hobby.
    The printer is an ex demo, it came with no manual or software to install.
    I specifically asked the salesman if it would be difficult to achieve what she wanted to do given the limited knowledge, i asked him if i would need training in graphic design or be an experienced printer. He said no as the printer was really easy to set up and was just like a bigger version of our desk top printer, its a big plug and play printer. I also asked if i needed a RIP, he also said no everything would be fine.
    so now i find myself with a printer that i cant use, people taliking about ip addresses, RIPs, crossover cables etc all of which i was not told about.
    I can find my way around a pc and can follow pc intructions easily so if anyone could do me a step by step guide from scratch i would be most grateful.
    The printer works as i have done a testpage manually from tghe printer.
    I have downloaded the following drivers from canon:
    Garo Printer Driver (Add printer wizard for Windows2000/XP/2003) (2.51)
    Garo Printer Driver (Setup Programme for Win2000/XP/2003) (2.51)
    GARO Status Monitor v2.50 (v2.50)
    Canon NetSpot Console for Windows v4.10.2a (v4.10.2a)
    GARO Status Monitor v2.41 (v2.41)
    my next step will be to get a pro in to set it up or i might stick it on ebay
    thanks in advance
  • Richard Barker
    28 May 2006 at 22:24
    i have just downloaded the canon setup utility and drivers and installed again.
    got a little bit further on the driver install as the w8200 came up in a "add printer" window.
    when i used the utility program i had to re-input the ip,subnet mask and g/w default back in to the printer menu.
    I did a ping on ip,subnet mask and g/w default which test ok, but the ip that printer is set to, i get timed out messages.
    i have tried all combinations of crossover cable and normal ethernet cable. i have tried direct from pc to printer and through a netgear wireless router with both cables.
    any more ideas?
  • Jamie Wood
    28 May 2006 at 23:40
    Hello,
    I could be wrong, and stand to be corrected, but I am fairly sure that you will not be able to simply use this as a plug and play printer. I would expect that a printer of this size needs an independent RIP, not just a Windows printer driver. Hopefully, someone running a similar type of machine will be
    able to clarify.
    I have a friend who has just bought the same machine, and he has been
    talking about having to buy a PC and RIP to be able to use it.
    Sorry I can’t be of more help.
    Cheers,
    Jamie.
  • Richard Barker
    29 May 2006 at 07:48
    thanks jamie
    i will get on to the salesman as i made it clear that we are novices and we needed something that was easy to use.
    i installed the posterjet Rip trial late last night and i still no joy.
    does anyone know of a company or person in the Rotherham/Sheffield area that could come and set me up. I am willing to pay.
    thanks
