Home Forums Sign Making Discussions Neon, LED, Lighting cannot see lighting through lightbox case?
  • cannot see lighting through lightbox case?
    Posted by Deleted User on 4 September 2006 at 08:00
    Hi Everyone,
    Just a little bit of advice needed. We recently installed a 10 metre lightbox for a new customer. The customer was one of those with a bit of a dusty wallet who knew what he wanted but didnt want to pay for it. We therefore constructed the lightbox with 100mm signcase and used 3mm opal perspex. Now however the customer is complaining that you can see the tubes when its lit. Would replacing the 3mm perspex with 5mm opal fix this problem, or is a whole new box required? Again, all help much appreciated.
    David Rogers replied 19 years, 3 months ago 3 Members · 6 Replies
  • Dave & Rob Lowery
    4 September 2006 at 08:09
    I would be tempted to cover the rear of the panels with white translucent vinyl and see if that is the cheap way to get round it 😕
  • Deleted User
    Deleted User
    4 September 2006 at 08:40
    Not a bad idea dave, never thought of that mate.
  • David Rogers
    4 September 2006 at 08:49
    Or get some ‘prism’ styrene or acrylic to diffuse the lights.
    In 100mm casing with 3mm opal – not much you can do as the lights are so close to the face.
  • Deleted User
    Deleted User
    4 September 2006 at 09:28
    whats prism styrene dave?
  • Dave & Rob Lowery
    4 September 2006 at 09:30
    Prism acylic is like loads of small diamonds on the surface of the acrylic that refracts the light.
  • David Rogers
    4 September 2006 at 10:02
    It’s used for diffusers in offices etc. in suspended ceilings. Most plastics suppliers will have it.
