Home › Forums › Sign Making Discussions › Computers – Tablets – Phones › cannot load fonts with xp & service pack 3
Posted by Marcella Ross on 19 August 2009 at 10:10Has anyone had any problems installing fonts with Service Pack 3? I’m having a nightmare after installing fonts onto my new pc which runs SP3. It’s causing software to crash. The error code it shows is a font load error.
I can’t get any work done because I can’t get to my fonts ๐ฅTim Painter replied 16 years, 4 months ago 10 Members · 30 Replies -
http://www.techsupportforum.com/microso … maged.html
marcella read the bottom post im sure it was the same system as yours, might help ๐
Thought it might have problems. I’m not installing it. my systems run Ok so why fix it if it’s not broken.
Dont mean to hyjack but I downloaded ie 8 after a prompt and I’m now having to use firefox.
didnt like ie 8 for some reason which I cant remember and tried to go back to a restore point now ie wont even open.
hope my cutter still works.
just read that and have gone into the registry. Followed the instructions ……. but I already have a REG_DWORD entry called SessionImageSize there?????? Only difference is that the decimal value is different.
Should I change this value? ๐ฎpanic panic panic ………….. this type of computer stuff scares me!
oh registry has got to be spot on…could you copy and paste it here? ๐
quote Marcella:just read that and have gone into the registry. Followed the instructions ……. but I already have a REG_DWORD entry called SessionImageSize there?????? Only difference is that the decimal value is different.
OMG ๐ฎ do i dont i ๐ ๐
Back up your reg BEFORE messing with it!
quote Marcella:OK – I’m leaving it alone! ๐ฎ
good move ๐
here’s the instructions for the fix
Open the registry editor (regedit)Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Add a new REG_DWORD entry called SessionImageSize with a value (decimal) of 20
Reboot
The Type 1 fonts should now open/install without any problems.
But as I mentioned I have an entry of that name already although the value is different. ๐
yeah I know, that’s what I said. So the question was do I leave mine alone with a decimal value of 16 or change the value?
quote Marcella:yeah I know, that’s what I said. So the question was do I leave mine alone as it is or change the value?
yeh go for it :lol1:
right if I change it to 20 and something horrible happens, can I change it back to 16 and be back to where I am now? Or will it blow up burn my hair, ruin my nail polish and blister my face? ๐ฎ
quote Marcella:Or will it blow up burn my hair, ruin my nail polish and blister my face? ๐ฎ
yeh probably :rofl: :rofl:
I think that registry entry is more specific to Graphic card problems.
Marcie are any fonts showing under control panel, appearance – themes , fonts?
If you try and preview the font by clicking the file in the fonts folder does it display OK?
If you open something simple like Notepad and type some text can you highlight it and change the typeface ok?
ok I confess to not knowing a lot but if the help forum sais you need a value of 20 in the registry and you’ve only got 16 that must be why yours isn’t working so as said back everything up and change it – you can undo it if it doesnt solve the problem.
A puter with no fonts is as much use as a chocolate teapot ๐ฎ
Marcie the
"SessionImageSize"=dword:00000020
20 value apparently refers to allocated memory you can increase it.
I would also check that you have the latest drivers for the graphics card from Dells site.
Also after changing registry entries you need to Reboot to take effect.
if you still have NO joy, what Graphics card do you have?
Tim.
too many technical questions ………….. I dunno! LOL.
The graphics card on the pc (says me looking at the Dell paperwork)
Video Card Integrated Intelยฎ Graphic Media Accelerator X4500
so do I change the value, is the majority vote that I change it? My face won’t blister then?
๐ฎ
Out of interest do you run Corel and if so do you get the same problem installing fonts with Font Navigator?
Alan D -
Yes change it…………..you can blame me If it all goes pear shaped as I’m the other end of the country :lol1:
