Home Forums Sign Making Discussions Computers – Tablets – Phones cannot get broadband connection with windows 2000?
  • cannot get broadband connection with windows 2000?
    Posted by Derek Heron on 3 February 2005 at 06:05
    hi all any ideas windows 2000 professional
    connect to broadband as normal no problem opens on home page when
    i type in any other address i get unable to connect page
    wont even go back to home page .i have to re boot PC
    any thing simple before i ring helpline
    cheers Dex
    Derek Heron replied 20 years, 11 months ago 4 Members · 4 Replies
  • Paul Goodwin
    3 February 2005 at 08:58
    Could be a proxy problem at your service providers end, not sure though.
    one of the tech heads should be able to answer it soon
  • trevb
    3 February 2005 at 20:21
    First thing I’d check is to see whether your machine is infected with Spyware and/or viruses. Sounds like a browser hijack to me.
    Try typing in the following IP address in the address field to determine if the IP will route:
    http://212.227.22.121
    What happens? May be a DNS problem, but I suspect it may be a hijack.
    Spybot, Highjackthis and Adaware are 3 good utilities to remove spyware.
    Trev B
    CADlink
  • Gordon Forbes
    3 February 2005 at 21:56
    I don’t know for sure but did you download any updates Service pack 2 for XP can give this problem with a DNS error couldn’t find server on some systems and the fix for that was to uninstall it and select repair instead of uninstall. So I have been told.
    Don’t know if it affects 2000 though.
  • Derek Heron
    5 February 2005 at 16:11
    hi again it looks as if it is down to Norton!
    i ran spy-bot and ad-aware cheers Trev b found them on nethomeelp
    and they found loads of stuff
    so rebooted and within seconds it was away again this is with norton switched on with updates current
    ran spybot etc again to clean up tried switching norton off
    and everything started fine email ok www ok no problems
    ran spybot and adaware both clean and found nothing
    so turned norton back on once again within seconds it all went belly up
    i have pc-cillin on my no1 pc and it seems ok
    i am in the process of trying to network everything together
    and get them all up to date
    i have a 4 port adsl router with built in firewall which i am told should help
    thanks for your help on this guys
