Home Forums Software Discussions Corel Software Cannot convert font to curves
  • Cannot convert font to curves
    Posted by Stacey Clinch on 23 July 2009 at 19:30
    HELP!
    I am trying to convert my image from CorelDraw and import it into Composer.
    I usually just convert the text to curves and then export it as an ai or eps…..then import it into Corel and I am away, but for some reason I cannot convert……the software just switches itself off.
    Has anyone got any suggestions of what I can do to to over-come this??
    Stacey
    Chris Lambe replied 16 years, 5 months ago 7 Members · 8 Replies
  • 8 Replies
  • Dale Farrell
    24 July 2009 at 07:07
    Morning,
    one thing you might try, which has worked for me is to install the particular font that you’re using in Corel into your GSP fonts. Then just export as an EPS without converting to curves. It should import without any fuss.
  • Stacey Clinch
    24 July 2009 at 07:36
    Good Morning Dale
    Thanks for that – I did try and convert the font, but it says ‘cannot write softfont’
    I haven’t got a clue what that means!!!!
    But thanks for trying to help.
    Stacey
  • Dale Farrell
    24 July 2009 at 07:41
    Never came across that myself! sorry I can’t be of more help. Best of luck with it.
  • Glenn Sharp
    Stacey,
    Have you tried breaking the font apart and converting it to curves in smaller chunks?
    I’m not really sure why that is happening for you but breaking apart might be worth giving a go
  • Adriano Fantini
    26 July 2009 at 11:46
    Sounds like it’s only the screen fonts you have and not the printer font. I’m not a Corel user but same thing happens in Illustrator if you do not have the printer font open
  • John Childs
    26 July 2009 at 19:45
    quote Adriano Fantini:
    :yes1:
  • John Harding
    27 July 2009 at 11:33
    why not post the file and see if someone else can sort it for you
    John 😀
  • Chris Lambe
    28 July 2009 at 14:25
    I have to agree with Adriano & John
