Home Forums Software Discussions Signlab Software Can you produce a halftone fade in SL
  • Can you produce a halftone fade in SL
    Posted by Phil Veitch on 8 July 2009 at 13:32
    Quick question can a halftone fade be produced in signlab??
    Need to produce some motorcycle stickers but they have a halftone fade on them, any ideas??
    thanks phil
    David Rowland replied 16 years, 4 months ago 5 Members · 6 Replies
  • Scott.Evans
    8 July 2009 at 13:38
    what version of sign lab are you using?
  • Phil Veitch
    8 July 2009 at 14:08
    7.1 print n cut
    8 July 2009 at 14:35
    You can if you have the thermal package, There are halftone palettes, but need to be used with spot colours
    I dont think there is another way to do it in signlab
  • Phil Veitch
    8 July 2009 at 18:24
    will have to play around again, just thought id pick the rains of you smart people.. 😀
  • cavedave
    3 August 2009 at 16:14
    Create you fade / gradient as normal and then use the
    Image – Filters – Stylize / Artistic – Halftone.
    It converts to a bitmap, but will apply a halftone effect.
    Best regards
    -David
    3 August 2009 at 18:15
    In Photoshop…. do ur fade with gradient tool… then Convert to 1bit Black and White, the half tone dots option is in there and make sure u match the printers resolution and make them round or diamond.
    Import this image to SL, colour it to what u want.
