Home Forums Software Discussions Signlab Software can you import a jpeg. file into Signlab 7?
  • can you import a jpeg. file into Signlab 7?
    Posted by Vince Francis on 17 August 2005 at 13:22
    Is there any way when you import say a jpeg, you can transform it to a wire frame only?
    Not had this long, and much more complicated than 5!
    Thanks in advance
    Vince
    Vince Francis replied 20 years, 3 months ago 3 Members · 3 Replies
  • Frank Droog
    17 August 2005 at 19:42
    Do you mean “View” / “Show Bitmap Outlines”
    Shortcut key should be ALT M
    This relaces the bitmap with a bounding box rectangle of the bitmap to save Redraw time.
    frank at cadlink
    17 August 2005 at 20:08
    Vince i thing you are trying to digitize?
    Do you have the the module do do it?
    double click the bitmap and in should either become editable or want to convert to black and white.
    You can then trace it, but first you will need to posterize it, There is actualy a demo built into signlab that shows you the basics as a video.
  • Vince Francis
    18 August 2005 at 21:14
    Thanks guys, im back in the office tomorrow, i will give it a try
    Vince
