Home Forums Sign Making Discussions Graphic Design Help Can you help to improve this Jpeg please?
  • Can you help to improve this Jpeg please?
    Posted by Karl Williams on 12 February 2010 at 20:32
    Customer has given me this to draw in. Doing it wouldn’t be a problem if it was better quality but as you can see……..it’s crap! Anyone got the software to improve this for me? Would be a big help. Thanks.
    Karl Williams replied 15 years, 10 months ago 12 Members · 18 Replies
  • 18 Replies
  • Terry Bull
    12 February 2010 at 21:06
    Karl
    if you have got p/shop move it there and play with the blur settings though it wont be brilliant you may loose some pixelling,try sharpening as well
    might help
  • Karl Williams
    12 February 2010 at 21:20
    Tried it Terry. Still looks crap. I need to draw it in so I can cut it out for some kick boxing suits.
  • Phil Craddock
    12 February 2010 at 21:45
    unfortunately if the file size and image quality is too low then its a case of ‘crap in- crap out’ if you know what I mean.
    If the quality or sharpness isn’t there to start with you wont improve it – I would quote the customer to re-create it or they send you a higher res or larger file/better image.
  • Karl Williams
    12 February 2010 at 21:53
    No mate, there’s been a topic on here before regarding some software that improves low res images. Just has to be a bit better for me to draw in.
  • Phil Craddock
    12 February 2010 at 23:36
    I have heard of a bit of software called Streamline many moons ago which converts photoshop images into a vector graphic but Illustrator can do that now anyway.
    hope you can get it sorted.
  • Gary Birch
    13 February 2010 at 07:10
    Karl
    I have just tried it in Photozoom and to be honest it’s just as sh1t as it first started mate. You normally get at least a bit of improvement but not this time mate.
    Gary
    13 February 2010 at 08:23
    Karl
    There are a couple of similar ones on istock vectors, maybe download a thumbnail to give you a better starting point to trace?
    I’m sure Ive seen that image somewhere before though, must be on the net somewhere..
  • Liam Pattison
    13 February 2010 at 13:10
    could you try and convince them to have something else along the same lines which would be easier to trace?
    http://www.dreamstime.com/royalty-free- … age6485929
    Liam
    13 February 2010 at 16:15
    the answer is no… if u partially shut ur eyes u can sorta see an improvement but not much… so u need to ask them "what is it" and google it
  • Karl Williams
    13 February 2010 at 17:01
    No joy on anything chaps. Thanks for your help.
    It’s just a sh!t image.
    13 February 2010 at 17:11
    you could employ someone with artists expression to re-create it, maybe someone with paint brushes?
  • DonMarco
    13 February 2010 at 23:55
    Recently I had similar case where customer wanted to have print from
    internet picture. Of course resolution was not useful.
    I gave file to artist to draw it again on paper and than I scaned it.
    Cost for artist was around 100 pounds but he spent several hours for drawing. I would spent even more trying to redraw in Photoshop or Illustrator.
    Saso
  • John Childs
    14 February 2010 at 00:33
    Isn’t this sort of thing what Vectorwise is for?
    14 February 2010 at 00:37
    am i losing the plot here…..if you vectorise it then fill in the layers to get the image effect, why would you need to employ a "digital artist" to do it? i was under the impression we were all "digital artists" totally confused.com 😮
    14 February 2010 at 06:38
    quote Nicola McIntosh:
    am i losing the plot here…..if you vectorise it then fill in the layers to get the image effect, why would you need to employ a “digital artist” to do it? i was under the impression we were all “digital artists” totally confused.com 😮
    I think saso gave it to a ‘real’ artist Nik, then scanned it and revectored that file.
    Personally, I tell them if they can’t supply me with a decent pic, then I can’t supply a decent sign.
    I’ll find a similar pic on istock or vectorstock and give them that option. Otherwise, I spend my time helping out other clients that aren’t as much trouble.
    If it is off the net, changes are its copyrighted anyway?
  • Terry Bull
    14 February 2010 at 11:21
    Karl
    ive drawn this, its hard to define a lot of the detail but if its not to be used too large it may suit ok
    Terry
  • Kevin Flowers
    14 February 2010 at 17:56
    Karl
    here’s a eps file from Terry’s drawing hope it helps might need tidying
  • Karl Williams
    14 February 2010 at 22:33
    Thanks Terry & Kevin. There both brilliant. I owe you both a pint at Sign Uk this year. 😉
