Home › Forums › Sign Making Discussions › CNC Router and Engraving › can you do engraving using your plotter?
Posted by Lorraine Clinch on 24 May 2007 at 11:41I have seen a bit of kit advertised on the dreaded Ebay which claims to allow you to engrave with a plotter. Does anyone know if it works? In actual fact I suppose there is co reason why it shouldn’t work on thin substrates….
Anyone have any experience of this?
Brian Hays replied 18 years, 6 months ago 11 Members · 13 Replies -
Lorraine unless it strengthens the head carriage and running gear then it would be a non starter, you would need a new head carriage within several months of doing this type of work on a normal vinyl cutter.
Nigel -
as nigel says, your machine will be gubbed in a matter of weeks. ide think sooner though… 😉
this is ebay at the end of the day, people with zero experience telling you anything to get a sale and not giving a damn after…you can tell i love that place… 😉
Thanks for that guys, sound advice, never thought about the strain on the head. I shall avoid!
Its probably just scratch engraving on very thin substrates.
My advice would be to avoid like the plague. -
Its not so much the thickness of the substrate, but the material hardness. Soft materials cause more drag on the cutter thus increase the loading on mechanical components of the machine. Harder materials need more down pressure and again your back to the drag coefficient.
I run a small flat bed engraver and do not take on stainless steel jobs for the same reason……its too demanding of the machine.Basically you can fit the engraving tool to any plotter (pen/cutting) however the harder you make the machine work the less time it will work for. With time you will loose accuracy as the back lash in gear trains and wear in bearings increases.
Protect your investment and keep your machine to doing what is was designed to do.
quote James Martin:Is there any chemical option you could use?
for engraving james?
James
Acid etch works a treat!!! Anything you can cut on your plotter, you can "engrave"
I tried posting a brass plaque I did last night (the posting bit, not the plaque). It still didnit show up. Actually, I done it twice (posting, that is), the first time with a long description on how, what, where etc, the second time (after "loosing" my first post while trying to preview it!!) a short and sweet version. Hang around, maybe the post will eventually make it’s way into the members portfolio…. I must have used the wrong size bitmap or some such. -
Was thinking about messing about with this but forgot about the damage to the head.
