Home › Forums › Software Discussions › Adobe Software › Can you create a barcode in illustrator?
Posted by Jason Davies on 14 October 2011 at 10:53Is it possible to create a barcode using illustrator 5?
Jason Davies replied 14 years, 1 month ago 6 Members · 10 Replies -
it is not possible to just type in a barcode. There did use to be a plugin for Illustrator, not sure it is still supported though. The program do use the font on the link, but barcodes are not direct replacements letter for letter !!There are programs to create barcodes, might even be a freeone.
Most retail UK barcodes are CODE 128 format. but it can get very technical, very quickly.
Theres plenty of sites for QR codes too – 3D barcodes if that helps
Thanks, I needed to draft up a proof earlier away from the office. Now I’m back I can generate these in Omega.
Cheers all.
Corel has been able to do it for some while, if you have a copy of that you could put the file into Illy.
Alan D -
http://www.terryburton.co.uk/barcodewriter/generator/
Can do most barcode formats and it exports to EPS so you can import it into Illy/Corel.
